On accelerating, under load (usually up hill), I notice a faint lag in pull/torque that repeats until I increase rpms a thousand.
Does the same whether soft or hard pressing on the gas.
(Manual Trans).
Passengers do not notice it, nor do the rpms drop any.
Torque peaks at about 2500rpms to ALMOST 155ft-lbs, then dips down, then rises again to a peak of 155ft-lbs at 4400rpms, so in between there, there's a lull for some reason... it's obnoxious but I donno what to tell ya
Sounds like its just what final described, a hole in the power band... downshift :P B)
