03-27-2007, 09:22 AM
Dash-LED Conversion
I am looking to do a LED Dash conversion, the stock is green, but i want to change it to Red, i dont kno if there has been a Tutorial put up on how to do this, but if anyone has done this, could they please send me the steps in a PM on how to do it?
03-27-2007, 10:25 AM
Stock is green?? are you looking to change the backlighting, or specific bulbs?
If your just looking to change the backlighting bulbs, thats not too hard. I'm currently running 2 different colors.
Links:
http://i178.photobucket.com/albums/w...terior0019.jpg
http://i178.photobucket.com/albums/w...terior0025.jpg
the red shows up just as bright as the blue (i put a resistor or two inline with the blue so its not SUPER bright) but the red didn't show very bright on my camera.
if that is what your looking for, i don't think there is a HOW TO for it. But the job isn't that hard.
03-27-2007, 10:32 AM
yea, the original backlighting is green, and its super icky, specailly since my Cd player backlighting is Red... they dont go good at all, so i want a color like blue so that it looks semi sweet
So its a matter of removing the dash, and once you know which ones tro replace, pop out the old ones and put in the new? im ok at soldering, so will soldering be required?
03-27-2007, 10:53 AM
there are 7 194 bulbs in a plastic clip behind the gauge cluster. There are two different ways to do it....
The first step is getting the cluster out. Its pretty easy. There are two screws in the top of the plastic outside the gauges. Take those out, and pop the black plastic outer ring out. then there are 2 screws up top, and 2 more below the cluster, to hold it in place. Remove those, and unclip the wire harness from the top right.
03-27-2007, 10:57 AM
Then you have to do the led conversion. The 194 bulbs (bigger ones in there) can just be twisted and popped out. With a little work, the bulbs come out, its easier to take a small screwdriver and straighten the wires in the clip, so they pull straight out.... instead of breaking them and trying to get the pieces out.
I've seen people replace each bulb with 1,2or 3 leds. I used one of each color, so i can switch back and forth... which takes more work. But if you just use one, you can carefully solder a resistor in there, and just put the proper conacts back through the plastic clip. twist it back into place, and your done.
Me? i chose the harder method. I reran 3 wires from each one. One blue, One red and a ground. There is enough room back there for you to do that, but you'll have to be careful to protect your solder joints, so you don't short anything, and have metal contacts touching the circuit board, which could present problems.
03-27-2007, 12:02 PM
or you could just buy some 194 Red LED bulbs and replace the regular 194 bulbs with those....... no soldering, and no wireing... that's if you just want one color.... I did that with my gauge cluster.... It's sooooo much easier than all this soldering stuff. lol Here's the site I got my bulbs from
http://www.superlumination.com/
03-27-2007, 12:05 PM
Can i get these bulbs at Advance Auto cheap?? or do i need to get them online
03-27-2007, 12:07 PM
I couldn't find any at Autozone... IF you do, and they are cheaper, I'd get them with autozone... but this is about the only site I found and the cheapest.... They aren't that expensive..... to me they aren't. lol
03-27-2007, 12:30 PM
if you do that, make sure the glass is coated, NOT just a film on them. (probably cost a little more that way)
cuz that film will fade, and you'll end up with pink or something. i went w/ LEDs cuz the color is permanent, and i already had then around....
03-27-2007, 08:25 PM
what glass???? I'm confused...
03-27-2007, 08:36 PM
the glass in the bulb. the 194 bulb itself.. (maybe its hard plastic.. i don't know)
03-27-2007, 08:57 PM
he is talking about the colored sleves you can put over your stock lights to change the color
03-27-2007, 09:08 PM
Thanks turned out great... i found a 2 pack of the 194B at AdvanceAuto for like 1.50/PAIR.. i just need to get 1 more bulb.. looks sweet so far
03-27-2007, 09:17 PM
oh I wasn't talking about the film cover stuff.... lol
03-27-2007, 09:20 PM
yea i would like to know what the dome light bulb is if i wanted to get an LED for the tube looking one
03-27-2007, 09:27 PM
i went ahead and deleted the other thread since this one was well into the direction of answers needed......don't take offense I'm just trying to help
OCA Alero Chapter Member!!!!
ALERO-LESS
03-27-2007, 09:36 PM
the tube lights should be 3157? from superbrightleds.com
03-29-2007, 10:42 AM
nice, the dome lights are the next ones im doing. the center ones(two small ones) are 194s and the tube one(im stll trying to find, in blue)..
03-29-2007, 03:43 PM
If I can get a good picture to turn out, I'll snap a pic of my interior lights... I replaced all the lights with white LEDs (the two in the mirror, the one in the dome light, and the two under the dash).... The other two in that dome light, I put blue LEDs in, but rarely use them cause of the police... Other than that, it looks pretty cool. I'm thinking of doing the same thing with my new car whenever I get it... I like the Whiteness of the LEDs.
03-29-2007, 04:02 PM
i replaced my dome light with 12 white leds. just hot glued them in... and wired them to the terminals. 4 facing front, 4 center, 4 back.
only problem i have with it, is that it lights up nice and bright w/ the car running (~14.5V) but really dim w/ just the battery (~11.5V) since i toasted my battery twice.
