03-27-2007, 09:28 AM
Low speed idle shudder
I'm having a small problem with my Ecotec. Sometimes when I rev the car a bit, and the RPM's drop down again, they fall too low and the engine almost dies, but then brings itself back up. The same thing happens when I'm idling and then turn the fan on. It'll *almost* stall and then perk back up.
I noticed my Fuel Pressure Regulator is leaking a bit where the two halves meet, and I could smell a bit of fuel in the vaccum line to it. Could a bad FPR be causing this problem? Seems pretty likely to me but I just thought I'd double check.
Thanks all!
03-27-2007, 09:52 AM
my car does the same thing on my 3400, if u tap the gas the RPM will go up, then drop and then raise back up like you are pressing the gas, when really you arent, i just figured it wasnt a big deal but if anyone knows the problem let me know
03-27-2007, 10:06 AM
I didn't think it was a big deal either until it looked like my FPR was leaking a bit.
03-27-2007, 10:14 AM
lol i havent checked anything, oh shit i forgot i have to change my oil today! thx for the reminder hahah
03-27-2007, 10:16 AM
Mine did that but threw a code and turned out to be a O2 sensor on the down flow
03-27-2007, 10:20 AM
nah no codes for me not sure what it could be i just got used to it after i almost hit a few cars at drive through lines an such
03-27-2007, 10:22 AM
Haha
"Move damnit. I'm Hungry!!"
03-27-2007, 10:24 AM
no.. its like it would be giving the car gas while i have my foot on the brake and i would accelerate forward for a second then it would drop back to idle RPMs lol
03-27-2007, 10:29 AM
This isn't the same thing. Mine drops below the normal idle.
I just made a video showing what happens.
I'd also appreciate it if you guys wouldn't whore my thread. Thanks!
03-27-2007, 10:35 AM
I had the same thing as both of you. I know exactly what you are talking about.
So you are getting leaks around your FPR. Most would say check your fuel pressure and oxygen flow and last time I checked, we both have been asking questions and giving suggestions.
03-27-2007, 10:37 AM
Yes, you both have been asking questions and giving suggestions. This however?
Originally Posted by AGT
Haha
03-27-2007, 10:40 AM
We've stayed on subject...let it go. So you do not have a code and that is the only thing odd mechanically with your car?
03-27-2007, 10:45 AM
No codes, and yes. Thats the only thing. I changed the fuel pump a little while ago, and just did new plugs yesterday. No change. The fuel pump actually cratered and Its time to do the plugs, I didnt change both just to try and fix this.
It also only does it when the motor has warmed up. I've got a fuel pressure gauge, I just haven't checked what the pressure is doing when it happens yet. Probably will today.
03-27-2007, 11:25 AM
I'm no car expert... but my Alero is always doing stupid stuff like that. I say start from the ground up. Go fill up with a tank of premium, throw some fuel injector cleaner in it and some condensation remover. See if that makes it any better.
03-27-2007, 12:04 PM
He's right...buy the cheap fixes 1st and hope they do the trick
03-27-2007, 01:12 PM
Mine kinda does that too, not as bad since my idle is higher (because I have a 5-speed). I wouldn't really worry about it too much. However anything leaking fuel should be a concern.
03-27-2007, 01:31 PM
I've ran premium in the car since I bought it months ago. I also threw a bottle of concentrated cleaner in the car when I bought it as well.
I'll keep my eye on the regulator. Its not leaking much, just had a trace amount of it on the outside.
Thanks for the replies all!
04-09-2007, 10:34 PM
mine does the same
bone stock 2003 Ecotec w/ automatic. Same damn thing. Seems to be worse in warmer/hot/humid weather.
I noticed this 1st summer of the car's life, when it was 6 month old. Dealer was no help (no codes, we can't help you).
Sometimes in worst cases it does in fact stall out unless I keep the revs up to 800 RPM via the accelerator.
I liked the video idea. I should have done that 3-4 years ago, and shown it to the dealer!
Good luck. This may wind up being one of those 'ya gotta live w/ it' things.
'03 Ruby Red GL1 4 Dr, Ecotec auto. All options but leather. 16 inch factory Argent wheel upgrade, Potenza RE910s, Powerslot front rotors, factory deleted cargo net replaced. Hi/lo beam Silverstars.
04-09-2007, 10:45 PM
Yeah I'm not going to worry about it anymore. Seems like its just one of those things it does.
