03-27-2007, 01:46 PM
Canadian... Eh?
Timing chain replacement
Does anyone know when the recommended time would be to change the timing chains on the ecos.
I've got 125,000km, and think its probably due.
03-27-2007, 02:22 PM
Yeah it sure couldn't hurt...really look at the tracks of the serpentine and see if you have an perpendicular cracks that cross the entire width of the belt. I know that an outside crack would definitely need changing
03-27-2007, 02:32 PM
From all I have heard, Timing chains service should be done after only 200 000km. However, a Timing BELT should be changed after 100 000km.
I don't know what is in the ecotec.
03-27-2007, 03:08 PM
My bad I completely read the title wrong.
03-27-2007, 03:38 PM
Canadian... Eh?
yeah I'm just kinda scared b/c I heard some horror stories about the chains snapping in the ecos prematurely.
03-27-2007, 10:56 PM
Boost Guru
Yeah, belts usually get changed at a certain mileage or when excessive wear is present. A chain (like on the Eco) will last a pretty long time without having to be changed. So I'd say unless you're having problems with it right now, you'll still be good for a while.
The Ecotec was pretty much over-engineered and built to handle a lot. I doubt anything you've heard about snapped timing chains is true.
03-28-2007, 12:57 AM
It was only the older Ecotecs that had issues with their chains snapping. There was something wrong with the tensioner and/or lubrication system for it. There's a way to tell if yours has the updated stuff, it's posted at http://www.z22se.co.uk/
03-28-2007, 01:26 AM
UnOrThOdOx
you should also do the chain for the balance shafts while your in there
03-28-2007, 02:16 AM
I wouldn't worry. I've never had to do that on any of my vehicles.... or any vehicles at my place. My dads old truck had 455,000kms on it too...
03-28-2007, 09:52 AM
Canadian... Eh?
I'll have a look at that site, thanks guys.
