Old 04-05-2004, 10:57 PM   #1
tklucero
First of all cool site, I'm new here. My question is will a offset of 35 work on a Alero. Also will it look ok. I'm also new at wheels by the way. Second, I've seen where others have used wheel with bolt pattern 5x114.3. Should I be hesitate to try these on my Alero. Any advice will be appreciated. Thanks!!
Old 04-05-2004, 11:23 PM   #2
Naich
The Founder
Naich's Avatar
yeah, 35 offset should be allright.
Click here for more info... http://invision.aleromod.com/index.p...oadpage&f=rims
Also, as for the bolt pattern, 5x114.3 should be fine but you might need hubcentric rings if the bore of the rim is larger than the bore of the hub.
