Old 05-22-2007, 11:27 PM   #1
white04alero
white04alero's Avatar
white04alero has a little shameless behaviour in the past
sub box shape
does the shape of the box matter?
for my kickers that i ordered tonite, i'm making the box a 14" x 14" x 15.5" box. this makes it right at 1.75 cubic feet. (about 1.7538)
is a cube a good box shape or should i go different
2004 Olds Alero GL1 3400 V6
- pioneer 4900iB head unit
white04alero is offline   Reply With Quote
Old 05-23-2007, 12:11 AM   #2
antichrysler
shape doesn't matter.... it's all displacement
Old 05-23-2007, 01:19 AM   #3
your supposed to research what size box your subs hit the hardest at and then make that size box.
Old 05-23-2007, 01:25 PM   #4
foosedgrandam
also u need to brace the box too
Old 05-23-2007, 02:30 PM   #5
white04alero
i did research the size, and 1.75 ft is perfect, especially if i want to go ported later, i was just wondering if the size mattered.. but if its just displacement, and the size doesnt matter, then im good. thanks guys
Old 05-23-2007, 02:31 PM   #6
white04alero
and what do you mean brace the box? to the car? or inside the box??
Old 05-23-2007, 06:39 PM   #7
icpurplepplalot
trust me with those cvr's you won't need to brace it, just make sure you use 3/4 mdf
Old 05-24-2007, 01:32 AM   #8
white04alero
ok, i used 3/4 mdf board.. and the boxes are finished execpt for the front, its going to my dad's machine shop to get the 12" circle cut out... then itll be put onto the box.. and then itll be carpeted
Old 05-24-2007, 04:36 AM   #9
white04alero
one more thing.. if i were to port the boxes, what frequency should i port them to? and how long should the tubes be and the hole
Old 05-24-2007, 08:16 AM   #10
antichrysler
you could port the boxes..... but i wouldn't recommend it unless you know exactly what your doing.
the size and length of the ports is dependant on the sub and how big of a box you're making. If you're making the box for 1.75ft^3 then odds are for a ported you'll need the box to be around 2.25ft^3 and then you'd have to calculate out the length of the port. From where you're at right now I would say just leave it as sealed and you'll be happy.
Old 05-24-2007, 05:15 PM   #11
white04alero
recommended for sealed: 1.0 ft^3 to 4.6 ft^3
recommended for ported: 1.75 ft^3 to 2.25 ft^3
Last edited by white04alero : 05-24-2007 at 05:16 PM. Reason: forgot to add "to 2.25 ft^3"
Old 05-24-2007, 08:41 PM   #12
icpurplepplalot
Are you wanted to vent it or use aeroports? WHen I build ported enclosures, I always use the "vented" or "L port" method.
Old 05-24-2007, 09:13 PM   #13
antichrysler
you're doing 2 12's right?
Old 05-25-2007, 12:27 AM   #14
white04alero
yeah in single boxes, and im talking about ports.. the circle holes with the tube in them
Old 05-25-2007, 09:14 AM   #15
antichrysler
ahh best bet... download winisd
try to tune for 40hz with a delay less than 10ms... even 10ms is borderline for me... especially if your listening to rap music and such... that'll give you what you need
i know in my old ported box (phoenix gold 12") it was 3" wide and about 10" or so deep... don't remember off the top of my head though... so i wouldn't use those values
Old 05-25-2007, 09:37 AM   #16
white04alero
i have winisd.. but i just dont know how to use it after you put in all the parameters.. im winisd-tarded
Old 05-25-2007, 09:53 AM   #17
white04alero
and i have one more question.. about the subs.. ok.. right now i have a scosche 550 watt max amplifier.. and i am getting the money for the 500 dollar 750wrms kicker amp to power the 2 subs.. now.. my q is can i power the 2 subs with the scosche for a while and then hit em with the 750 or should i just wait and install them when i get the 750? will underpowering them so much with the scosche hurt them? its a 150 dollar (buy one get one free) investment that i want to make work for me when i can.. so can anyone help me? will the underpowerment of my 550 watt max amp hurt the nice 400 wrms of the kickers?
Old 05-25-2007, 10:22 AM   #18
antichrysler
nah... you'll be fine. The only time underpowering speakers is an issue is if your max power is about 15-20% of what the sub can handle. If you're at about 50% you'll be fine.
Old 05-25-2007, 10:23 AM   #19
antichrysler
As for WinISD I'll see if I can do anything tomorrow. I don't have it installed and I'm at work till 5 and then I'm visiting my folks this weekend.
Old 05-26-2007, 02:07 AM   #20
white04alero
i appreciate it thanks
