Old 05-28-2007, 05:34 PM   #1
Subwoofer/amp questions
Ok well im not modding my car anymore.. i sold off what i hadnt yet installed. However, im just gonna drop a nice system in it in the meantime. I can always move my system to my new car, right? yehh...
The subs i got... (2 of them, just ordered 'em!)
http://www.alpine-usa.com/US-en/prod...odel=SWR-1242D
I played around with all kinds of setups in the store and the alpines were what appealed to me most. Really loved these subs.. no suprise considering i have R's in the rear deck and S's in the front doors already...
--> THE PROBLEM IS, im an audio retard so what kind of amp should i get to go well with these subs? Needs to be at least 1000w right? jeez i dunno. I need a 4 channel one apparently. Preferably find it for me on here ( http://www.etronics.com/mysearchcat....re=&catid=8042 ) the prices are amazing. I like the one that glows colors too woohoo!! =D lol.
I have a friend around here that will construct a decent box for me for now.. i would like something custom eventually but thats for later..
Also am i gonna have to worry about the lights fading a lot with these? What should i do? Get a high output amp and red top or something? I dont want to if i dont have to. (for now)
Thanks for being patient with my audio negligence
Old 05-28-2007, 07:05 PM   #2
Brent recommended this amp
http://www.etronics.com/product.asp?...re=&catid=8056
sounds good to me unless anyone else has something up their sleeves.
Old 05-28-2007, 07:53 PM   #3
sofa
sofa's Avatar
sofa is an unknown quantity at this point
Send a message via MSN to sofa
Yeah id go with sumthing like that for the subs..DEF. A MONOBLOCK and a class d is a good choice...yeep ur looking for sumthing @ 1000watts @4ohms remember the 4 ohms of the sub b4 deciding on an amp be sure the pair up..good luck and have fun
Straight.From.Steel.City
http://www.cardomain.com/ride/2313940 http://www.myspace.com/kowch
sofa is offline   Reply With Quote
Old 05-28-2007, 08:30 PM   #4
blindman
blindman is on a distinguished road
i have 2 alpine type r 12" 4ohm( so ya wat u have) wired up in parallel so its a 1 ohm load, with http://www.rockfordfosgate.com/produ...n_US&p_status=
and a 3 farad cap and it sounds great and the the power series is really under rated...its rated at 1000 at 1 ohm but the pvc says its 1600 at 1 ohm so it runs them just fine...i havnt even had the fan kick in on it, it kicks in at like 60-70 degrees celcius i think...so thats just my opinon but that kenwood is pretty nice to
blindman is offline   Reply With Quote
Old 05-28-2007, 09:32 PM   #5
foosedgrandam
personally I would suggest goin to a Memphis Dealer and get a Memphis 1000 watt amp they arent that expensive. then u actually get a warranty on the product u buy. I may be Biast since I'm a MECP tech on buyin things off the internet.
Old 05-28-2007, 09:39 PM   #6
SweetNLow
SweetNLow's Avatar
memphis is awsome stuff....... but im positive its way more money than she was looking to spend
joelsoundxtreme: u faggot
Old 05-28-2007, 09:53 PM   #7
antichrysler
sweetnlow is right
personally i'm not a big fan of kenwood... they're kinda like the kia of amps
if you want something good that's in between the price of the kenwood and the memphis you may want to consider phoenix gold or alpine
one thing to keep in mind... low end amps always claim higher wattage but have a higher distortion rating... so you never actually use the power
Old 05-29-2007, 04:00 AM   #8
icpurplepplalot
get a hifonics 1606d, and you'll bee good, those type r's can take some power
Old 05-29-2007, 08:56 AM   #9
Vinalero
Vinalero's Avatar
Originally Posted by antichrysler View Post
sweetnlow is right
I had the same opinion of Kenwood in the past. I bought my KAC-729 600W about 5 years ago and after she's seen 4 cars, moisture, water then ice in the trunk, over power, weak subs, dents and scratches, it still plays like a charm. That's probly the best buy I ever did.
I blown two cerwin vega 12 inches with that amp that were rathed at 600W peak that the guy at the store told me it was the right thing to buy. (that's within a year, one has been repared and blew again) After those I went for a Kenwood 12 inch that was on sale (300 W RMS, 1000 peak) and the guy told me it was too big for the amp. Have it for 2 years and a half and no problem so far, better quality than before, clear bass.
All around ppl keeps telling me that Kenwood is build tough and can handle a lot. I guess next time I have to buy audio things, I'll consider Kenwood again. But I think its just a question of taste, every brands have different class of product.
Old 05-29-2007, 10:11 AM   #10
white04alero
white04alero's Avatar
white04alero has a little shameless behaviour in the past
since youre gettin alpine subs, try to see what alpine has in the way of amps.. because typically i have found that if a company makes a subwoofer, they make an amp to go with it (typically)
2004 Olds Alero GL1 3400 V6
- pioneer 4900iB head unit
white04alero is offline   Reply With Quote
Old 05-29-2007, 10:14 AM   #11
white04alero
this might be a little much, but heres what i had in mind... something like this:
http://www.alpine-usa.com/US-en/prod...del=PDX-1.1000
Old 05-29-2007, 10:50 AM   #12
yeh thats ridiculous. i found a mono block alpine one on my site for 300 bucks but thats just not what i was looking to spend right now. I dont have a job (i quit) but you know how i roll, i gots money in teh bank
im getting the kenwood then. Hell i didnt even need this thread im just iming brent next time! I'll let yall know how everything turns out
^^isnt that the same thing u posted for 800 bucks? hhaa grand =D
Old 05-29-2007, 11:48 AM   #13
antichrysler
awesome! hope the new stereo sounds good... be sure to post pics
Old 05-29-2007, 12:31 PM   #14
i love how those alpines sound. The type X's sound better but cost a helluva lot more lol. Im a bit of an audiophile.. i have 2 different systems in just my room alone, lol. woot woot ordering amp now subs are already on their way
Old 05-29-2007, 01:12 PM   #15
antichrysler
lol yeah... alpine's got some good stuff... never owed any of it personally but heard lots of good things about it
if only paradigm/klipsch made car audio... i'd be all over that
Old 05-29-2007, 07:44 PM   #16
Wow...
I would of taken the previous advice and looked into a Hifonics amp of sorts. Directed even...
Kenwood. Bose. Sony. Who is next? Old popular names living off the past.
You have 2 dual 4 Ohm subs. Your wiring options are this:
Mono:
1 Ohm or 4 Ohm
2 Channels:
2 Ohm or 8 Ohm
Or of course, 4 channels @ 4 Ohms.
If you are trying to power the R's @ 4 Ohm, get your purse out.
I would highly advise looking into a better brand amp, even if it is $50ish or so more than the Kenwood.
Old 05-29-2007, 08:10 PM   #17
the better options i was looking at are more like... $200 more in price. Im doing pretty good considering i dont have a job right now lmao.
Old 05-29-2007, 10:59 PM   #18
Have you looked for a JBL BP1200.1?
It would do you wonders.
Directed has a 1200 wrms amp also.
Theres plenty of shops out there.
www.ikesound.com
www.sonicelectronics.com
www.mmxpress.com
sheesh how many more legit ones. Just watch out for e bay punks like "indo audio"...
Actually E bay used would be a good place to look...
