Old 05-29-2007, 11:14 PM   #1
Mischief007
Mischief007 is an unknown quantity at this point
Send a message via MSN to Mischief007
Car starts and stops almost right away.
2002 Olds Alero with the 2.2 Ecotec Engine and a 5-speed. 118,000 km.
Came to a gas station from my 100 km commute. During the commute, the Security light came on and stayed on for the rest of the trip. Once I filled up (and I fill up here every other day), I go to start the car, the car starts, and then stops immediately but before it stops, it sputters to a stop.
It just sat there for 10 minutes, started up fine. Turned off, started again, had trouble keeping idle and then died. IAT?? But then again, pressing on the gas didn't do anything either.
http://files.filefront.com/Aleroavi/.../fileinfo.html
??,??? km
??,??? miles
Mischief007 is offline   Reply With Quote
Old 05-30-2007, 12:57 PM   #2
Mischief007
Passlock failure. Should have the car back in a couple of hours.
??,??? km
??,??? miles
Old 05-30-2007, 10:19 PM   #3
antichrysler
warranty?
Old 05-31-2007, 06:30 PM   #4
Mischief007
Originally Posted by antichrysler View Post
warranty?
No but it is fixed.
??,??? km
??,??? miles
Old 05-31-2007, 06:31 PM   #5
How much?
Old 05-31-2007, 11:44 PM   #6
Mischief007
Originally Posted by Redog View Post
How much?
Is assraped a word?
It wasn't bad compared to the rates here in Canada. With taxes (14%) it was $737 CDN with towing as well.
??,??? km
??,??? miles
Old 06-01-2007, 01:22 AM   #7
antichrysler
good lord........ that repair cost more than your cars worth
Old 06-01-2007, 09:44 AM   #8
Mischief007
No. the car is still worth a lot more than that.
??,??? km
??,??? miles
Old 06-01-2007, 10:08 AM   #9
antichrysler
yeah i'm just buggin'
how much of that was the repair and how much was the tow?
Old 06-01-2007, 11:29 AM   #10
Stanl3yX
Stanl3yX is an unknown quantity at this point
Send a message via AIM to Stanl3yX Send a message via Yahoo to Stanl3yX
hey, i had these same symptoms...
http://www.aleromod.com/forums/showthread.php?t=17996
its still in the shop, still waiting on that call from my mechanic...
New and Want to MOD
I have 2000 Red Alero
2.4L Twin Cam with 15" Tires
Stanl3yX is offline   Reply With Quote
Old 06-01-2007, 12:47 PM   #11
Mischief007
$300 for parts
$310 for labour
$35 for towing
??,??? km
??,??? miles
Old 06-01-2007, 04:04 PM   #12
freakout
freakout's Avatar
freakout is an unknown quantity at this point
Ouch, pricey. Mine does the same thing at least once a week. Wait 10 mins start with the remote works fine!
freakout is offline   Reply With Quote
Old 06-01-2007, 05:31 PM   #13
antichrysler
That's expensive... I wouldn't put that much money in to fixing any car... well, at least not in one go
Old 06-01-2007, 11:52 PM   #14
Mischief007
This kinda is my daily driver and I commute to work 100 km each way (200 total) everyday.
I really had no other choice.
??,??? km
??,??? miles
Old 06-01-2007, 11:53 PM   #15
Mischief007
When it stops starting, check the fuel pump relay .
??,??? km
??,??? miles
Old 06-02-2007, 11:41 AM   #16
freakout
freakout's Avatar
Thanks. We try to start it with the remote all the time. When I get a new key cut, it doesn't do it for a little while.
Old 12-10-2014, 02:31 PM   #17
WreckItRoth
WreckItRoth is on a distinguished road
I had something similar after my first rebuild and i couldnt figure out what the hell it was. I actually discovered the problem with mine by mistake. Theres a fuse that is bolted on by the trans and as i would hit bumps on the road it would slowly move down and as soon as the metal on the bottom of the fuse grounded with the trans it would sputter flash security and die. Then after trying to start again it would run for a tiny bit hit some bump and down she goes. I tightened it like hell and wrapped it so it wouldnt ground out regardless if it did come loose and never had the problem again.
WreckItRoth is offline   Reply With Quote
Old 12-11-2014, 12:59 PM   #18
zzyzzx
zzyzzx's Avatar
Do they all have this or just the 4 cylinder model transmissions?
Old 12-12-2014, 11:11 PM   #19
Fabian_7s
Fabian_7s is on a distinguished road
Happened to me once after changine the brakes.. Started the engine just to give the new brakes a few test stops then after i parked it and turned it off. 10 minutes later i realized i had to get something from the store and the car turned on for 5 seconds and just died. Kept cranking and cranking but it wouldnt stay on. The security light was on on my car as well so all i did was disconnect the battery for 30 seconds and reconnected it and it started up just fine.
Fabian_7s is offline   Reply With Quote
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
