Old 06-03-2007, 11:12 AM   #1
nate1216
Stupid Fuel Filter
Ok. I know there are some other posts related to this but I just cannot for the life of me figure out how to get the quick connect fitting disconnected. I bought the little tool for about 6 bucks, but I have two problems. When pulling away the green clips, I don't see what to depress to get the thing to release, also do you need to get a low profile tool? I can't seem to get enough clearance between the fitting and the filter? Id really like to do this myself, it looks easy enough and I don't feel like paying 71 bucks(conrads) to have someone else do this.
Thanks.
Nate
Old 06-03-2007, 11:31 AM   #2
rustyballs_69
Its Beer Thirty
rustyballs_69's Avatar
When I changed my filter that green clip had to come all the way off. I don't remember exactly but I think you just push one side in then out.
Old 06-03-2007, 12:39 PM   #3
DOHC_tuner
DOHC_tuner's Avatar
yeah I had problems taking mine off, I even had a friend help and we couldnt get the dam thing off. The dam quick disconnect tool wouldnt fit between the the line and the filter. So best thing is get a plastic quick disconnect tool so you can bend it so it can squezze in there. The dam haynes manual shows the filter with white tabs that you just press and release but my filter didnt have that. Good luck
Old 06-03-2007, 01:38 PM   #4
alero_ecotec
Special Agent
alero_ecotec's Avatar
alero_ecotec is an unknown quantity at this point
I just changed mine last week, it was pretty easy I thought. Only problem is that I can't really figure out how to put it into words to explain it.
I'll try to draw a picture...hold on.
THE Ohio State University!
alero_ecotec is offline   Reply With Quote
Old 06-03-2007, 01:51 PM   #5
alero_ecotec
Special Agent
Attachment 2262
Alright, I hope that kind of helps. Once you get the clip open, take that flathead and then push The green clip away from the fuel line (push on the green clip at the top points of the U it makes when it's open), I found that it's not necessary to take it all the way off, just remove it enough so you can take out the old fuel filter. Be careful though, do not break the side where it's connected to the flap that snaps in, if you do that you're screwed.
Old 06-03-2007, 05:45 PM   #6
alero_ecotec
Special Agent
sending this back to the top in hopes the guy who started the thread sees this.
Old 06-11-2007, 10:17 PM   #7
nate1216
Thanks
I am going to give that a shot next time I have some free time on the weekend!
Old 06-11-2007, 10:26 PM   #8
antichrysler
i changed my fuel filter once... i just took it to my dads mechanic
Old 06-11-2007, 10:29 PM   #9
nate1216
most of the goons around here won't put in my part(fram brand new in package) they want to put in their own and charge me 30 bucks for a 10 dollar filter. Plust 45 in labor. My buddy has a Grand am, so if i can figure it out I can make some $$ off him. I solved the hesitation I was having by two bottles of fuel system cleaner(probably a gunked injector) so I am ok for now, but I have about 57k, and want it changed before 60k.
