Old 06-03-2007, 05:50 PM   #1
blindman
blindman is on a distinguished road
hummimg
idk if its cuz im being retarded lately or wat but every since i got this alero i have had nothing but probs with system...
n e ways my problem is that i get this humming out of the subs (kinda like hearing a car behind u with small subs) just this constant RMS power pretty much.......it will start to hit when its just highs so i pause it to and the subs are still going....ill turn the sub off on the HU and it will still go.....i thinks its a ground sumwhere cuz when i hit a bump or the subs it hard it stops doing this. i checked the amp and cap ground and those look fine, a friend said its prob a ground loop on the HU so im gonna take that out tomorrow and check all the wires and ground
the humming is kinda like when u have ur RCA's over or next to the power cables, its like its getting an outside signal from sumwhere
also it dont happen everytime....like if i go across town (20 min drive) it will prob so it for like the last 2 min...it usually starts once ive been going for a while
blindman is offline   Reply With Quote
Old 06-03-2007, 06:25 PM   #2
check the RCA cables, also make sure your lines arent rubbing or anything
also, have a friend listen to the subs and while the car is in park give it gas, if it stops humming when you give it gas, that means you have a bad ground somewhere
Old 06-03-2007, 08:38 PM   #3
blindman
where did u guys ground ur HU
Old 06-03-2007, 10:07 PM   #4
bratch15
bratch15's Avatar
bratch15 is on a distinguished road
I have always just matched the wires up for the HU...they say your supposed to ground your HU to something else in the dash, but I just connect it to the factory ground and I have never had any problems with any of my three cars I owned...Another idea, do you have your battery wire and remote wire separated? The first time I hooked a system up in my car I didnt separate the wires and I had humming noises, and some popping noises when I would put my turn signals on
2004 3.4L Alero GL, CAI, Clear Corners, Reverse Glow Gauges, Alpine headunit w/Audiobahn subs and amp
http://www.cardomain.com/ride/2538269
bratch15 is offline   Reply With Quote
Old 06-03-2007, 10:30 PM   #5
blindman
ya i have my HU to the factory ground.....i have my remote and RCA down the right side and power down the left side of the car....so idk
Old 06-04-2007, 02:02 PM   #6
icpurplepplalot
check your rca's and make sure they are not pinched anywhere.
Old 06-04-2007, 04:03 PM   #7
blindman
ok i just checked all the amp and cap grounds, they look fine. the rca looks good. so my only conclusion is its the HU ground, which sux cuz hate dealing with the HU on these aleros cuz there is like no room to work in there
cuz when i put in a cd it starts to go and sum other stuff (its kinda hard to explain i guess, its easier to show u) but ill rip out the HU tomorrow and let u no if that helps
Old 06-04-2007, 04:54 PM   #8
teflone
teflone's Avatar
teflone is an unknown quantity at this point
ground loop isolator.
Cure that ricky tick
teflone is offline   Reply With Quote
Old 06-04-2007, 05:33 PM   #9
blindman
thats a good idea i might try that....i think i still have one laying around here sum where
