Old 06-11-2007, 10:07 AM   #1
tonyboi261
tonyboi261's Avatar
tonyboi261 is on a distinguished road
Help Please!!
ok so my little black button on the shifter has just fallen off.. what i need to know is how to dissassemble the the shifter so i can get a better look at it
99 white alero 4 door-R.I.P you will be missed
92 opal green civic 4 door-h22 turbo running mid 11s
"i might not look like much but im a pro at pretending to be a ninja!"
tonyboi261 is offline   Reply With Quote
Old 06-11-2007, 10:13 AM   #2
AGT
AGT's Avatar
would be better off getting a replacement shifter...
ebay had our shifters for cheap at one point
Old 06-11-2007, 10:15 AM   #3
tonyboi261
tonyboi261's Avatar
i think super glue can fix this problem and i wanna fix it before my dad sees it
Old 06-11-2007, 10:24 AM   #4
pull the pin out, its on the shifter.... get a pair of pliers and pull the pin out, after its out, it will slide off.
Old 06-11-2007, 10:38 AM   #5
antichrysler
i'm really curious how you managed to break that
Old 06-11-2007, 10:50 AM   #6
tonyboi261
tonyboi261's Avatar
i dont know the button just popped off i can still shift it but its kinda tricky....i found a thing on the front it doesnt look like a pin and its definately not coming out maybe mine is different??
Old 06-11-2007, 10:59 AM   #7
Vtolds
H&B Shipping Agent
Vtolds's Avatar
If it is the automatic then there is a C clip that you have to pry out with a small screw driver or something like it. There is no pin in the Automatic Shifter.
Old 06-11-2007, 11:21 AM   #8
tonyboi261
tonyboi261's Avatar
i tried to get that lil curvy pin ..thing but its on there too good ....but upon further investigation i figured out that on the button the part that broke off was a kinda pointing out thing because inside the shifter there is a hole and because when you push the button in it goes off crooked so there is a hole in the button and inside the shifter thats where a kinda rail thing used to go ...i looked for it under my seats and everything but i cant find it so im gonna make a makeshift one till i find out where i can get a short shifter
Old 06-11-2007, 11:58 AM   #9
Vtolds
H&B Shipping Agent
Vtolds's Avatar
hmm you should just beable to pry it out. I did it many times on mine with just a small flat screw driver.
