06-15-2007, 11:32 PM
5 speed tranny
Where can I get a 5 speed tranny for my LD9?
06-16-2007, 12:14 AM
Southern Fly Boy returns
junk yard
06-16-2007, 08:02 AM
You'll need more than the tranny hehe.
pedal, cluch master cylinder, center console, I believe a new cluster (But i bet it could work even with the speed shits in the middle of it), Cables, Shifter, Clutch, Flywheel, etc...
But your answer is still what Mixtape said
06-16-2007, 10:14 AM
See j-body.org for lots of info.
06-17-2007, 12:02 AM
transmission, clutch resovoir, flywheel, flywheel bolts, clutch kit, transmission mounts front/rear/side, shift linkage, shifter assembly, clutch pedal and all of its bullshit, reflashed pcm for 5spd calibration killing all the auto tranny settings. other small things.........
06-17-2007, 08:57 PM
okay so where can i get it, if i go to the dealer how much would it cost?
06-17-2007, 10:11 PM
Junk yard. You need to raid a 5-speed Alero for the parts. You would be getting royally raped at the dealer.
??,??? km
??,??? miles
06-18-2007, 08:34 AM
Is there anything that the dealer wont rape you for ? lol. I'm learning junk yards are the best if you want stuff like that.
- (2000 GL) 14.748 @ 93.04
- Doctor Speed Cold Air Intake
- DHP PCM / 180* Tstat
- General Exclaim UHP Tires
- 2 1/2" Pacesetter Exhaust
- S&S Headers
06-20-2007, 05:58 PM
Boost Guru
You could use a 5 speed Grand Am also. Just the tranny itself you can get from 2000 and up J-body's, too. I don't know what else you can use from the J's, but the tranny is the same.
06-20-2007, 08:08 PM
if you get a tranny from a jbody, you can use the shift cables and the shifter assembly in the cabin, just have to find a way to bolt it down. I would hope, if the shifter assembly doesn't exactly bolt into the n-body floorpan that drilling a new hole for it wouldn't be TOO far out of anybody's skillbase.
06-20-2007, 08:09 PM
None of us work at a dealership. Thought about calling? I can get you the phone number to three of them here in Las Vegas.
