Old 06-18-2007, 10:46 PM   #1
DOHC_tuner
DOHC_tuner's Avatar
Upgrading Brakes
Well since im going boosted and adding some nitrious I need to upgrade my brakes first, so whats brands do ya'll recommend? I heard of BAER and wilwood but cant seem to find a application from wilwood for an alero.
Old 06-18-2007, 10:53 PM   #2
mfuller
Baer and SSBC (Stainless Steel Brakes) are the only companies (that I know of) that offer bolt-on high-performance brakes for the Alero. Anything else (i.e. Wilwood, Brembo, Alcon, AP Racing) will be a custom application.
Old 06-19-2007, 12:09 AM   #3
DOHC_tuner
DOHC_tuner's Avatar
what about a good flowing aftermarket radiator?
Old 06-19-2007, 01:18 AM   #4
you can do the 12" upgrade with GM parts like i did, or any system that uses the orignal caliper mounting for a '98-'02 camaro would work too.
Old 06-19-2007, 03:35 AM   #5
strtrydr
strtrydr's Avatar
^you still have the parts list for the upgrade?
i will need this shortly too
Old 06-19-2007, 06:39 PM   #6
megabyte
megabyte's Avatar
megabyte is an unknown quantity at this point
There's a good thread on the GrandAmGT forum here
megabyte is offline   Reply With Quote
Old 06-19-2007, 07:58 PM   #7
MixtapeMessiah
Southern Fly Boy returns
MixtapeMessiah's Avatar
depends on how much money u got to spend on it. Baer and SSBC would be the high end models and if u just wanna do rotors and pads I went with brembo crossed/drilled rotors and hawk ceramic pads.
Old 06-19-2007, 08:17 PM   #8
strtrydr
strtrydr's Avatar
nah ... gonna need bigger brakes period ... the more I look at the z06 swap the more i dont really see the differance between them and the SSBC/BAER setup except for like 60 bucks more you get 13" Disks with the SSBC Kit instead of 12" in the swap
ugh ... freakin killing my brain
Old 06-19-2007, 09:22 PM   #9
rustyballs_69
Its Beer Thirty
rustyballs_69's Avatar
I would go with the Vette calipers and Impala rotors. Cliff what rotors did you use? I was looking at power slot for the rotors and they have the rotors for the SS. Would they work?
Old 06-20-2007, 08:10 PM   #10
spyhunter
spyhunter's Avatar
why do you need upgraded brakes?
Old 06-21-2007, 12:57 AM   #11
I just got today from Summit, the Summit brand slotted and cross-drilled rotors and pads.
I'm putting them on tomorrow
Old 06-21-2007, 02:22 AM   #12
strtrydr
strtrydr's Avatar
BlackJack is putting the turbo on my car soon
Old 06-21-2007, 02:01 PM   #13
DOHC_tuner
DOHC_tuner's Avatar
yeah thats the reason why I want to upgrade my brakes and suspension cause im adding boost.
Old 06-27-2007, 02:48 AM   #14
Ok, here's one other advantage. All the parts you need for the brake upgrade using the GM parts are readily available if you need replacements. If you want to go to a 13" rotor instead of the 12", you can get these adapter brackets for $295.
The Baer setup is actually OLDER technology. They just adapt C4 brakes to fit your car. I believe the SSBC kit uses C4 rotors and their proprietary C5-style calipers.
I have the rotors that are spec'd for a '98-'02 F-Body or a '00-'05 Impala or Monte Carlo.
There's a 4-pot SSBC kit on ebay right now listed for a venture that should also work (have to drill the mounting holes in the knuckle to 14mm probably)
