Old 06-20-2007, 05:58 AM   #1
Eh_nigma
the "Why Not?" Guy
Eh_nigma's Avatar
Eh_nigma is an unknown quantity at this point
Send a message via MSN to Eh_nigma
Engine Temp in Deg. F?
Alrighty, Haynes is telling me that 2.2L is supposed to run at 180 deg. F. However, after it running for 20 minutes, I'm sitting at a steady 142 deg. F. Anyone know something I should?
-Everything
"Why an Alero?"
-Why the hell not?
Eh_nigma is offline   Reply With Quote
Old 06-20-2007, 09:04 AM   #2
antichrysler
Those do seem a bit low. If it was winter I'd just say your fan isn't working properly but it's probably not that cold right now.
Maybe it's a bad sensor?
Old 06-20-2007, 09:10 AM   #3
DaRockwilder
DaRockwilder's Avatar
DaRockwilder is on a distinguished road
My 2.2 sits steady at the half way mark on the gauge. I have no idea what the temp is, since its only marked in C and H. Even with the A/C on on a hot day, thats where it hangs out.
DaRockwilder is offline   Reply With Quote
Old 06-20-2007, 07:21 PM   #4
Eh_nigma
the "Why Not?" Guy
Eh_nigma's Avatar
Normally mine sits 2 widths of the needle below center on the normal ones... if only we knew what the range was on that stock meter...
-Everything
"Why an Alero?"
-Why the hell not?
Old 06-20-2007, 09:56 PM   #5
Satsuriku
V.I.P. Punching Bag
Satsuriku's Avatar
well my car is a 3.4 but mine sits around the same but when she idols, it tends to go slightly higher then the half mark but by very little, then it just drops down natually cause of the fan so personally i say your should be ok but never hurts to be sure
Old 06-21-2007, 10:54 PM   #6
Eh_nigma
the "Why Not?" Guy
Eh_nigma's Avatar
I wont know for sure until I get it out and run it... however, due to it's current state on the jacks... yeahhhh... until then though, I'll have both on there...
-Everything
"Why an Alero?"
-Why the hell not?
