Old 04-08-2004, 09:40 AM   #1
Green Eyed Monster
Has any one seen this....I need a touchscreen but don't want to get anouther mon. I was wondering if these will work ok or not??????7" Touch Panel
Old 04-08-2004, 10:00 AM   #2
wy3134
Hmm seems awefully cheap....but for those prices worth the risk? i guess its that saying u get what u pay for
Old 04-08-2004, 03:15 PM   #3
BLK03GXS
BLK03GXS's Avatar
It should work ok... I guess it just converts basic screen to touch... would be interesting to try... its basicly would just be a replacment for the mouse... i guess
Old 04-08-2004, 04:03 PM   #4
niral622
niral622 is an unknown quantity at this point
hmm, the price sounds about right...here's another kit which is for xenarc monitors...in theory it should work for any 7" monitors (99% sure on it), but just to make sure, i would call them up and ask...
http://www.xenarcdirect.com/detail.a...DUCT_ID=XE7TSK
the one you found will also work, but only on that size monitor (7")...just out of curiosity, what kind of monitor do you have?
2003 Black GL - Sedan and No sunroof
niral622 is offline   Reply With Quote
Old 04-08-2004, 04:06 PM   #5
niral622
by the way, make sure that if you get a "touchscreen kit" you have the drivers, usb controller, and touchpanel...without any one of those, you'll have some trouble
also, heres the installation walkthrough for the kit:
http://www.digitalww.com/TouchKitInstalation.htm
Old 04-08-2004, 05:17 PM   #6
Green Eyed Monster
it is a Pyle 7" tft
Old 04-09-2004, 02:06 AM   #7
niral622
yeah installing the touchscreen shouldnt be a problem if you know what you're doing and are careful--make sure you avoid contact with the screen's circuit board because your body has static electricity stored in it and that static could zap the sensitive electrical components on the board...where to mount the usb controller on the otherhand--three choices:
1) try to fit it inside the screen's casing (might not fit)
2) put it on the outside of the screen's casing (ghetto)
3) pull the wires through the hinge (or even outside the hinge) into the upper overhead console...(this is the one I would go with)
goodluck :thumbsup:
Old 04-09-2004, 03:04 AM   #8
Green Eyed Monster
thanx...I managed a computer shop for 2 years...I don't think I will have any prob's with the install. I just was wondering if this product was worth getting.......
Old 04-09-2004, 01:55 PM   #9
niral622
nice...then it should be cake
are putting the touchscreen in for a carputer? if so, what are the specs of it?
Old 04-09-2004, 03:21 PM   #10
Green Eyed Monster
Yes that is what I want it for ...I don't have the specs yet I have to build it...........I want a processor over 1ghz at least 80 gig hd , at least 512 mem. cdrw dvd combo......that is what I am shooting for.... :thumbsup:
Old 04-09-2004, 11:03 PM   #11
Aleromaster
Aleromaster is an unknown quantity at this point
Send a message via AIM to Aleromaster Send a message via Yahoo to Aleromaster
The onlything I would have to input on this is when you install the screen make sure there is not to much pressure on teh panel. I had to remount mine becasue the mouse was stuck in the left corner.
2002 GL2 4DR, MYMODS:In dash 7&quot; VGA Widescreen monitor, XM Satalite Radio, Clarion Amp, 2 10&quot; Audiobanhn DVC Subs Hidden HitchTrailer Hitch, Grill Mesh
Aleromaster is offline   Reply With Quote
Old 04-10-2004, 02:49 AM   #12
niral622
nice....
I want a high powered system but I can't do that yet since it takes too much power and i'm planning on using mastero's MK 3.5 (125 watts max power)....and idea on your power supply yet?
Old 04-10-2004, 08:18 AM   #13
Green Eyed Monster
Not yet I am looking in to it......I am also looking into a laptop with a broken lcd....I would like to just take the lcd off and use just the base........that would save a lot of room and time an the build.......they make a video converter converter 1 converter 2 I am not sure how the 2nd one works.......
Old 04-11-2004, 03:50 PM   #14
niral622
the second one is all you need....it converts the VGA signal to S-video or Composite...the first one looks like its some sort of signal switching box where you can choose which connector to output the signal to...
Old 04-12-2004, 08:54 PM   #15
Green Eyed Monster
thanx......that is what I thought.......
