06-25-2007, 12:24 PM
Electrical Problem
not sure what my problem is, but maybe one of u guys can help me out.
the symptoms:
car starts, but gauges, radio and power windows wont work. everything else is fine.
after driving for various amounts of time, everything starts to work like normal.
recently, turning off or on the a/c can cause the gauges and other symptoms to occur. also, turning on the cruise control sometimes takes care of the problems.
my theory is it is the ignition switch. what do u guys think?
06-25-2007, 12:38 PM
fuse panels got wet
06-25-2007, 12:54 PM
pretty sur that is not the problem, fuse panel hasnt gotten wet.
06-25-2007, 01:03 PM
BCM got wet then..
common problem..
It just screams of a water problem thats all..
Your BCM is in the trunk I belive on the right side.. I could be wrong..
Ever once thought something got wet in your trunk ? or there was moisture on something in your truck..?
06-25-2007, 01:42 PM
as far as i know, there hasnt been any moisture in there either. i've always got stuff back there, and it has never been wet when i get it out.
06-25-2007, 02:03 PM
UnOrThOdOx
I'd sure like to know too, mine does the exact same thing.
06-25-2007, 06:01 PM
UnOrThOdOx
Anybody????
06-25-2007, 06:22 PM
Its Beer Thirty
Sounds like a short of some kind IMO.
Originally Posted by Daytona
06-25-2007, 09:36 PM
Well, only thing you can do is try..
I would suggest taking out your whole gauge cluster, and re-installing..
It could be as simple as a loose connection..
I would start there..
But most if not all of what your talking about is the BCM module..
So unplug that, then plug it in..
Go get creative..
06-25-2007, 10:07 PM
Originally Posted by teflone
BCM got wet then..
common problem..
yeah your wrong
the BCM is located under the dash on the Passenger's Side
06-25-2007, 11:00 PM
yeah, your right..
That one is super easy to get to..
06-26-2007, 08:35 PM
i forgot to mention, the car starts when the key is simply in the on position, does not need to be turned all the way to the start position to start the car.
06-26-2007, 08:44 PM
UnOrThOdOx
Ok mine does everything you mentioned, except for that last one
