Old 06-26-2007, 01:15 AM   #1
Kardain
Kardain is on a distinguished road
Passlock + BCM = which wires
Ok, so I'm in the process of putting a 3400 in a J-body, and want to get a jumpstart on the theft-lock. the car the engine is going in doesn't have a BCM, and research leads me to believe that I can't disable the Passlock stuff in the PCM and eliminate the need for a BCM.
So, which wires exactly do I need to hook up to a BCM to allow the Passlock only.
these are the wires that I've ID'd so far:
C2-A6, Magnetic Rotation Detection Sensor Return
C2-B4, Magnetic Rotation Detection Sensor Signal
C3-A10, Ground-Clean
C3-B2, Serial Data Signal, Class B, 10400 Baud (Primary)
C3-B4, Magnetic Rotation Detection Ignition Key Cylinder Sensor Feed 12 Volt Reference
PCM is a 99 GAGT, and has not seen a BCM signal since I had it reflashed.
Or if there is a surefire way to shut it off using HPT, I'm very interested in knowing...
Kardain is offline   Reply With Quote
Old 06-26-2007, 01:19 AM   #2
strtrydr
strtrydr's Avatar
haha ... I just got done reading this thread over on 60*v6 ... good luck to ya though
Old 06-26-2007, 01:23 AM   #3
Kardain
yeah, I got a post in every v6 forum I know of... someone should know
