well check you remote make sure that your still getting a signal to turn the amp on (you can check this but using a small jumper wire and jump it from the constant to the remote). if its not the remote, then check the RCA's (you can check this buy running a really long rca wire out side your car and hook it up to your deck and if you get sound then your wires are bad). if you still get nothing check the rca's on the deck (hook another amp up or use the really long rca's and hook them up to a amp in somone else's car) hell maybe even check the subs to make sure you didnt fry them. but if everything checks out then you may just have fried your amp (one way to check if your amp is friend is to smell it and if it smells like smoke and dosent work, then its fried). but yea your amp is not the best on the market if you cant get it to work id just thow it away.
1991 Ford mustang LX Vert. 5.0L 302 Almost done
1995 pontiac bonneville. need trans, FOR SALE.
1991 Chevy S10, 4.3 5 speed 4WD
soon to come . . .
Ford F150 5.8L 351W
1999 Olds 88.
President, Sykotic Concepts.
www.myspace.com/QCmustang
www.myspace.com/SykoticConcepts
