Old 07-03-2007, 02:29 PM   #1
lovefrom1977
lovefrom1977 is on a distinguished road
Cleaning the engline
If i wanted to clean the engine, would i have to cover anything up or block anything from getting wet. Is it alright to spray it with a garden hose to just rinse it all off? Also is there anything else i need to know before i do it? Thanks
lovefrom1977 is offline   Reply With Quote
Old 07-03-2007, 02:58 PM   #2
troyertrain
troyertrain is an unknown quantity at this point
Send a message via AIM to troyertrain Send a message via MSN to troyertrain
i just pop the hood and spray mine, and nothing has gone wrong in all the times i have cleaned it...
troyertrain is offline   Reply With Quote
Old 07-03-2007, 03:09 PM   #3
Same here, most important stuff is waterproofed.
Old 07-03-2007, 03:29 PM   #4
tonyboi261
tonyboi261's Avatar
tonyboi261 is on a distinguished road
only thing is if you have a cone filter
99 white alero 4 door-R.I.P you will be missed
92 opal green civic 4 door-h22 turbo running mid 11s
"i might not look like much but im a pro at pretending to be a ninja!"
tonyboi261 is offline   Reply With Quote
Old 07-03-2007, 03:44 PM   #5
antichrysler
Also get some engine degreaser. That stuff works well.
Old 07-03-2007, 04:25 PM   #6
Vinalero
Vinalero's Avatar
I remember Sweet saying to use some Goo-Gone. flood engine, spray Goo-gone, wait couple minutes, then clean it. Also I remember that it is better to wash it while the engine is running.
Old 07-03-2007, 05:00 PM   #7
TheMeaningOfLife
TheMeaningOfLife's Avatar
Yea if you ahve a cone dont spray it take it off then seal the end of the intake.
or do as i did, if your to nervous to spray it get in there with some engine degreaser 4 diff sized scrub brushes and get to it, then wipe it all down with old rags.
Old 07-04-2007, 02:34 AM   #8
lovefrom1977
alright thanks guys, do i have to have the engine running or is it alright if i do it while it is off? Can i spray simple green all over everything also?
Old 07-04-2007, 02:42 AM   #9
Marrko
Marrko's Avatar
Marrko is on a distinguished road
Send a message via Yahoo to Marrko Send a message via Skype™ to Marrko
qestion: i have a cone filter... i need to remove it and seal the pipe (with what plastic bag or rags?)... but if i keep my engine running how will the air come to my engine if the hole is seald? and if i spray the engine won't it afect the alternator if water gets on it?
The Black Devil ---> American Heart and Soul representer in Europe....
Marrko is offline   Reply With Quote
Old 07-04-2007, 02:50 AM   #10
SIUlero
SIUlero's Avatar
SIUlero is on a distinguished road
engine off...you can make some problems if you do it with it running
SIUlero
'01 Alero GL
'72 Cutlass Supreme
http://www.cardomain.com/id/CrazyOldsGuy
SIUlero is offline   Reply With Quote
Old 07-04-2007, 07:25 PM   #11
Satsuriku
V.I.P. Punching Bag
Satsuriku's Avatar
you can do both without any problems, as long as you do it right. if you have a wai/cai, if you dont want to go through the hassle of taking it off, just take a couple of plastic bags and cover it up and tie it so its secure and dont have any leakage go through, and like someone else here said, get some automotive goo gone and spray her down, wait a couple of mins and wash it off
Old 07-04-2007, 10:04 PM   #12
I sprayed it on a rag and wiped the motor down, then I started the engine.
I don't like the idea of spraying the motor with a garden hose, but it is cool to see the steam come off the headers (if you have headers) but it's also neccessary. I didn't do that part last time and something started to burn, but I fixed that before it caught fire
