Old 07-03-2007, 03:20 PM   #1
Kanyon
Kanyon is an unknown quantity at this point
New Strut problem
So I lowered my car last month and decided I needed new struts too.I got KYB GR2s and tryied to do the back drivers side but cannot get the holes on the bottom to line up.The old struts were worn out and could be pushed up high enough to line up but these new ones won't budge.Anyone have any ideas?
My Forsale Thread
Black 2dr 2000 GLS
30% Tint - Lowered
Ported TB - Flowmaster Exhaust - WAI
7" Flip out DVD player - Ample Audio Amp - 2 10"s
Shaved Trunk
-Gone
Kanyon is offline   Reply With Quote
Old 07-03-2007, 03:58 PM   #2
MixtapeMessiah
Southern Fly Boy returns
MixtapeMessiah's Avatar
line up where? the top the the strut tower or the bottom where it connects to the arm? it was a two man job for me when I did it, I had to have a friend push up on the bottom so I could get the big bolt to go through the hole.
Old 07-03-2007, 04:10 PM   #3
Kanyon
Where it connects to the arm. I tried jacking the strut up from the bottom but that wont work.Did you tighten all the bolts up top first?
My Forsale Thread
Black 2dr 2000 GLS
30% Tint - Lowered
Shaved Trunk
-Gone
Old 07-03-2007, 04:24 PM   #4
MixtapeMessiah
no I put the big bolt on the bottom in first, hit it with an impact, put the tire back on then after that have a friend lower it back on the ground slowwwwwwwly and put ur hands up there and line it up til it fits into the top holes, I dont know whats wrong with urs, mine lined up perfectly with no problem what so ever.
Old 07-03-2007, 04:42 PM   #5
dont understand what your saying, but if you cant get the upper mount on the strut because of the resistance of the spring your going to need a spring compressor
Old 07-03-2007, 04:54 PM   #6
Kanyon
No I have the strut together, I put the top bolts in and am trying to put the bottom bolts in.I'll try doing the bottom first later on tonight.
My Forsale Thread
Black 2dr 2000 GLS
30% Tint - Lowered
Shaved Trunk
-Gone
Old 07-03-2007, 06:24 PM   #7
myowneq
myowneq is an unknown quantity at this point
I know I had to wiggle the arms on my a little to get them to line up. I also had to use a large screwdriver and hammer to line everything up on mine. I don't know how far out yours are. Maybe something's bent?
myowneq is offline   Reply With Quote
Old 07-03-2007, 06:35 PM   #8
Kanyon
It's almost like the strut is just too long.But i know I got the right thing.
My Forsale Thread
Black 2dr 2000 GLS
30% Tint - Lowered
Shaved Trunk
-Gone
Old 07-03-2007, 07:52 PM   #9
MixtapeMessiah
just try what I told you to do, bottom bolt first, lower the car with the tire on and line up the top of it to the holes and it should work fine
Old 07-03-2007, 09:15 PM   #10
oh the bottom bolts, get the bottom one in first, then use a jack and juck up on that rubber peiece thats near the rotors to help you get it into place. make sure you hand tighten very well, when i put my air ride in the bottom bolt came lose, caused a negative camber and the inner sidewall of my tire was rubbing against my strut. richie just had the same problem and ending up blowing his tire, so make sure you tighten those effers good
Old 07-03-2007, 11:11 PM   #11
Kanyon
Theres not enough room to even get the bottom hole lined up.It hits the top of the wheel well.They are the correct struts too I just looked up on KYBs site.
My Forsale Thread
Black 2dr 2000 GLS
30% Tint - Lowered
Shaved Trunk
-Gone
Old 07-03-2007, 11:23 PM   #12
Kanyon
This should show it
My Forsale Thread
Black 2dr 2000 GLS
30% Tint - Lowered
Shaved Trunk
-Gone
Old 07-04-2007, 12:11 AM   #13
TheMeaningOfLife
TheMeaningOfLife's Avatar
How do you have the car jacked up? By the body or a part on the suspention?
Old 07-04-2007, 12:56 AM   #14
remove the stabilizer bar end links. That should get you the room you need.
Old 07-04-2007, 02:02 AM   #15
looks like hes got it jacked up by a piece of the suspension and thats why its sitting so high in the pic
Old 07-04-2007, 03:06 AM   #16
MixtapeMessiah
dude jack the body up not the suspension pieces. Bolt up the bottom hole first then worry bout the top holes after, just do like I told you if ur jackin the body up u should be good after that seriously.
Old 07-04-2007, 01:14 PM   #17
Kanyon
I had the body jacked up not the suspension.Got a buddy to pull on the arm while i pushed on the strut and we finally got it lined up.But then I broke one of the bolts with the impact.Hopefully Autozone or Lowes has one that will work.
My Forsale Thread
Black 2dr 2000 GLS
30% Tint - Lowered
Shaved Trunk
-Gone
Old 07-04-2007, 04:19 PM   #18
MixtapeMessiah
go to autozone or napa, turn ur impact down u dont need so much torque for them
Old 07-04-2007, 04:53 PM   #19
Kanyon
Well I got it all togother but when driving you can here a rattling nosie that seems to be coming from the top of the strut tower.I noticed it before after I replaced the springs but hoped the new struts would fix it.And no it's not the boot that goes around the inside,already figured that one out.
My Forsale Thread
Black 2dr 2000 GLS
30% Tint - Lowered
Shaved Trunk
-Gone
Old 07-04-2007, 05:22 PM   #20
MixtapeMessiah
lol just let them settle and see if the noise goes away, I believe mine had a noise too for a while.
