Old 07-08-2007, 10:51 AM   #1
boostnsrt
zo6 wheels
does anyone know if the vette zo6 wheels will fit my 01 2.4? i like the look and im trying to stay with as much GM products as possible.
Old 07-08-2007, 10:54 AM   #2
jabartram
AutoCross Alero
jabartram's Avatar
all you need to know is bolt pattern and back spacing?
Old 07-08-2007, 10:57 AM   #3
boostnsrt
ok, where do i get the back spacing info?
Old 07-08-2007, 01:03 PM   #4
jackal2000
jackal2000's Avatar
if this is the style you want http://www.slickcar.com/productdetai...ProductID=4034
i dont see those fitting. they are so wide you will look like a gangsta mexican rolling down the road cause they will be sticking way out from the wheel well.
Old 07-08-2007, 01:47 PM   #5
boostnsrt
thats pretty damn funny, actually i just found some similar to the zo6 wheels online.
Old 07-09-2007, 12:54 AM   #6
Actually, the offset on the C5 wheels is just about right and they won't stick out much if at all. They have a +50 or so offset. I just see the 9.5" width being a problem, you'd probably hit the wheels on the struts.
You could use the the C6 style wheels in an 8.5" width though. It does require changing the bolt pattern on the car. You can bolt C5 rear hubs in the front of the Alero, they need to be bored a little but for the CV shaft to fit right. You should be able to use the front C4 hub bearings on the rear of the Alero with no troubles also. I haven't measured the rears out completely yet, but the front's DO fit perfectly. That will effectively convert your car from a 5X115 bolt pattern to a 5X4.5" (120.67mm) bolt pattern .
I've almost figured out how to get the 12" F-Body rear brakes to work too...
Old 07-11-2007, 01:29 AM   #7
boostnsrt
wow, sounds complicated.
Old 07-11-2007, 03:51 AM   #8
Spilner521
Boost Guru
Spilner521's Avatar
Yes it does. If your asking if the 'Vette wheels will bold right on, no they won't.
Old 07-11-2007, 03:53 AM   #9
Spilner521
Boost Guru
Spilner521's Avatar
More info would be nice
Old 07-11-2007, 08:31 AM   #10
jackal2000
jackal2000's Avatar
4.5" = 114.3mm, i think you meant 4.75".
Old 07-12-2007, 02:57 AM   #11
Yeah, i guess i typed that one too fast and forgot the 7.
For the 12" rear conversion, I'm waiting on some parts yet so i can figure out if it works as expected.
