07-23-2007, 03:03 PM
Car shaking when braking...
Hey guys, on steep downhills by car pullsates...or shakes! Also, my steering wheel shakes pretty bad also. I jacked up the car....and spun the wheels, but there did not seem to be a problem? So, what is causing my car to shake...maybe rotors...or pads?
Help Please
07-23-2007, 03:08 PM
take your car in and get a wheel alignment and get your wheels balanced
07-23-2007, 09:21 PM
Rotors probably. I just got a brand new set and vibrations under braking are gone. Do you have any vibrations at speed??
??,??? km
??,??? miles
07-23-2007, 11:14 PM
ya likley rotors are warrped.
2003 Alero
2.2 5speed
Grey
1996 GMC Yukon 4x4
07-24-2007, 03:23 PM
New and Improved
hey, i had much the problem that i think your describing. i took the car in and had the rotors refurbished, and problem is completely gone.
07-24-2007, 04:16 PM
I have the same problem, its warped rotors. and a bent steel rim in my case, but its balenced perfect now and still does it so it rotors. check you rims if you've ever spun out with steel rims.
And for the vibration at speed part, i never had any vibration with bent wheels utill the 90+ mark. hard to control under hard braking at that speed with warped rotors and a bent rim though. damn ducks.
07-24-2007, 04:21 PM
just noticed i didn't read the title of the thread... that has to be the rotors
07-25-2007, 03:37 PM
Ok...thanks guys
I figured it was the rotors, but wanted to check with you guys. How could I find out which rotor is bad?
07-25-2007, 03:51 PM
Originally Posted by redrider07
Ok...thanks guys
Look at them all, notice if one looks different than the other. its most likely one of your front rotors, they do 80% of the braking.
07-25-2007, 04:22 PM
My car does this, but only occasionally, and not always under hard braking. I have fairly new front rotors, the old are getting near needing replacing. How hard is it to warp a rotor from braking at high speeds ? Not jacking a thread i just realized i had the same thing happen.
- (2000 GL) 14.748 @ 93.04
- Doctor Speed Cold Air Intake
- DHP PCM / 180* Tstat
- General Exclaim UHP Tires
- 2 1/2" Pacesetter Exhaust
- S&S Headers
07-25-2007, 04:28 PM
Southern Fly Boy returns
either rotors are warped, brake pads are done or wore unevenly, or u need ur car aligned and/or wheels balanced
07-25-2007, 04:34 PM
Probably all of the above... I guess I'll have to get it looked at then. Pays to have a mechanics shop in your back yard ...well pays less lol
- S&S Headers
07-25-2007, 04:36 PM
its called do the work urself, brakes are easy as hell to do
07-26-2007, 01:36 PM
The Drunk
There is a special tool to check for checking runout if you want to be exact (something like this http://www.sjdiscounttools.com/cen6450.html )
You can probably find a much cheaper one cuz it's just some vice grips a snake like cable that can me tightened and a little gauge on the end that you can zero out and as you turn the rotor with the gauge touching it it tells you how far the gauge point is moving in that same spot. But you may as well do both sides at once.
`03 Alero GL 2.2L Ecotec
07-26-2007, 03:12 PM
my car did that too and i changed the rotors and it stopped shaking when breaking.
07-26-2007, 04:40 PM
The Founder
Yeah the stock rotors are terrible. Get brembo replacement rotors (tire rack has them).
07-26-2007, 05:30 PM
Yeah, I put wagners on mine and worked great
