Old 08-05-2007, 02:25 PM   #1
Satsuriku
V.I.P. Punching Bag
Satsuriku's Avatar
Power Window Problem
Ok, here is my issue.
The window for my driver side is just fine, my passenger side can only be open and closed from the driver side master controls, dont work with the passenger switch and both of the back windows won't go up or down at all, not from there switches or the driver's master switches.
Yes, recently i have taken the dorr panels off (only on the front doors) so i may replace the speakers but i plugged everything in there respective slots. anyone have any possible idea why it might be doing this?
Old 08-05-2007, 02:33 PM   #2
check and make sure u got it plugged back in all the way also see if u might of pinched a wire. might just be the master switch it self mine went out and i know others have 2
Old 08-05-2007, 07:46 PM   #3
mine does that sometimes, but i have no clue how to fix it b\c it will work again after a while. And i've had my door panels off about 4-5 times, rear also.
Old 08-05-2007, 07:54 PM   #4
rustyballs_69
Its Beer Thirty
rustyballs_69's Avatar
Have you checked your fuses?
Old 08-05-2007, 08:11 PM   #5
teflone
teflone's Avatar
teflone is an unknown quantity at this point
Your problem is the harness's.. they are slightly corroded/oxidized conductor greese would solve that problem..
Either that or a wire bristle brush to clean the connectors up..
just a tip! cheers
teflone is offline   Reply With Quote
Old 08-05-2007, 08:24 PM   #6
Satsuriku
V.I.P. Punching Bag
Satsuriku's Avatar
i looked at the fuses but even looking at the diagrams provided i cant seem to figure out what ones control the windows b/c there not clearly marked. if anyone could give me a tip there that would help.
also, ill have the tear apart the panel again to see if the wires are cooked something, that could be the problem as well
