Old 08-12-2007, 10:10 AM   #1
Bad99Olds
New and Improved
Bad99Olds's Avatar
Bad99Olds is on a distinguished road
Send a message via AIM to Bad99Olds
Maf
while i was working on my custom CAI set up, i was looking at the MAF, and noticed that the wire screen seems rater.. um.. restrictive. Is there a higher performance one that i could get to compliment my new set up.
Bad99Olds is offline   Reply With Quote
Old 08-12-2007, 10:31 AM   #2
as far as i know.. there isn't. removing or damaging that screen results in rough idle.
its not as restrictive as you think... its important. don't touch it.
Old 08-12-2007, 11:04 AM   #3
jabartram
AutoCross Alero
jabartram's Avatar
i've been running without my screen for over a yr with no changes in performance or idle, there are other maf sensors you can buy, granatelly and pro m, quite a few guys including BlackJack and myself in the near future are running an ls1 maf. so there are options, but changing the size of your maf on a stock motor is senseless.
Old 08-13-2007, 01:36 AM   #4
-Alero-
-Alero-'s Avatar
+1 ^^ no need to change the maf unless your goign for a fully built NA setup or boost. the MAF works just fine the screen restricts nothing but large elements......
AUTOBOT
