Old 08-20-2007, 02:12 AM   #1
JohnGuy
2001 olds alero question, please help!!
hey, i'm new here
ok....the other day i was getting an oil change and i had just realized that i never had checked my transmission fuel or even changed the oil.
i need help on finding the transmission stick?? anyone know where it would be?? i kept looking for a red stick but not found.
so, i read the owner's manual and it only talks about a transaxle, whatever that is?
the transaxle fluid cap is the only thing i found that remotely is like a transmission cap.
the problem is that there is no way for me to tell how much or little transaxle fluid there is.
so should i just for the hell of it add a little transaxle fluid?
thanks.
Old 08-20-2007, 06:10 AM   #2
im afraid i cant help you on that question. it was late when you posted this so people smarter than me will chime in tomorrow. welcome to the site. Clear your corners. (HAH). and take pics of your ho
Old 08-20-2007, 07:53 AM   #3
if yoru looking for a dipstick to check your tranny fluid... there isn't one.
Old 08-20-2007, 11:02 AM   #4
alero440
alero440's Avatar
alero440 is an unknown quantity at this point
Send a message via AIM to alero440 Send a message via MSN to alero440 Send a message via Yahoo to alero440
yep no tranny stick. Should just have the fluid changed when the manual says to do it, which is every 50,000 miles.
alero440 is offline   Reply With Quote
Old 08-20-2007, 11:59 AM   #5
alerored04
alerored04's Avatar
dont just add tranny fluid. That can lead to increased tranny pressures and excessive wear on the clutches. If you think it needs to be checked jack up the car on all four corners and get it level. Then pull the check plug on the underside of the tranny and see if fluid comes out. Otherwise have a shop do it.
My car breaks alot.
Old 08-20-2007, 01:33 PM   #6
DOHC_tuner
DOHC_tuner's Avatar
yup there is no tranny dipstick. For you to correctly read the level you have to jack it up level then remove the correct bolt, if tranny fluid runs out fast then its overfilled. It should run down slowly, the haynes manual tells you how to do it and which bolt to remove. good luck
Old 08-20-2007, 01:42 PM   #7
^^ What they all said.
I checked it myself, but at the mech's shop, since the car has to be level to do this
Old 08-20-2007, 08:46 PM   #8
JohnGuy
Thanks for your help everyone. I guess when i get more cash, i'll just go ahead and ask someone to change the oil for me cuz i'm assuming it's dirty.
