Old 08-26-2007, 04:27 PM   #1
trumpetplayer91372
trumpetplayer91372's Avatar
trumpetplayer91372 is an unknown quantity at this point
Send a message via MSN to trumpetplayer91372
engine problem
So a few days ago my service engine light came on and today I ran a scan of it and the code that popped up was P0440 evaporative emission control system malfunction. I reset my system and so far is hasn't come back on, but if it does pop up again, what would need to be replaced and how much would it cost?
trumpetplayer91372 is offline   Reply With Quote
Old 08-27-2007, 12:23 PM   #2
trumpetplayer91372
No one has had this problem before or has an idea of what it would take to fix?
Old 08-27-2007, 12:55 PM   #3
AGT
AGT's Avatar
This indicates that a part of the EVAP is no longer efftioning correctly. The EVAP system consists of many parts, including (but not limited to) the gas cap, fuel lines, carbon canister, purge valve, and other hoses. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
A code P0440 could mean one or more of the following has happened:
  • The gas cap is not installed or working properly
  • The purge solenoid has failed
  • The canister is plugged and not working properly
With a P0440 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try:
  • Remove and reinstall the gas cap, clear the code, and drive for a day and see if the codes come back.
  • Inspect the EVAP system for cuts/holes in tubes/hoses
  • Inspect for damaged or disconnected hoses around the Evap purge solenoid
  • Check and/or replace the sensor
  • Check and/or replace the purge valve
  • Have a professional use a smoke machine to detect leaks
