Old 09-07-2007, 03:54 PM   #1
terrylink
terrylink is an unknown quantity at this point
Dash Lights Area
Can anyone tell me if this area is a sealed unit or can a person get in there to work on it? I need to get in there to see if I can get the gas gauge needle below the upper peg. It is stuck above the peg so it doesn't show the proper amount of fuel in the tank. Any help on this is much appreciated. Thanks alot.
terrylink is offline   Reply With Quote
Old 09-07-2007, 04:53 PM   #2
Just pull the plastic trim around it off, unscrew the 4 screws (you need a socket wrench for that) and pull the cluster out. Then I'm not sure after that. lol but that gets the cluster out of the dash.
Old 09-07-2007, 11:58 PM   #3
SIUlero
SIUlero's Avatar
SIUlero is on a distinguished road
It all comes apart...pretty easy to figure out when you look at it
SIUlero
'01 Alero GL
'72 Cutlass Supreme
http://www.cardomain.com/id/CrazyOldsGuy
SIUlero is offline   Reply With Quote
Old 09-08-2007, 12:15 AM   #4
once you start looking at it, its pretty easy. i've had my cluster out on my lap b4.
Old 09-15-2007, 01:40 PM   #5
terrylink
Dash lights cluster
What I am wondering is if the plexi-glass on the front of the cluster comes off so you can get inside it to work on it?
Old 09-15-2007, 01:49 PM   #6
03alerospl
03alerospl's Avatar
03alerospl is on a distinguished road
yeah it does, once you get the cluster out, the glass just unclips off the assembly
03alerospl is offline   Reply With Quote
Old 09-16-2007, 12:56 AM   #7
SIUlero
SIUlero's Avatar
the clear part is glued to the black plastic around the gauge face, but it unclips from the gauges to give you access to the face...but be very careful with it, those needles are fragile
SIUlero
'01 Alero GL
'72 Cutlass Supreme
