Old 09-08-2007, 12:32 PM   #1
Quick Help!
Which is the stock oil pressure sensor?
A or B??
The haynes manual doesn't really specify, and has a really bad picture...
Old 09-08-2007, 12:33 PM   #2
shiny alero
shiny alero's Avatar
shiny alero is on a distinguished road
Send a message via AIM to shiny alero
ummm...B...but it could B A get it? lol....better ask someone who knows...lol
shiny alero is offline   Reply With Quote
Old 09-08-2007, 02:42 PM   #3
well... i tried A (since i had the socket to get it off) and it didn't work..
so its probably B. now i'm off to the tool store to find a socket that fits. 1" maybe?
Old 09-08-2007, 02:57 PM   #4
"A" is your knock sensor. "B" is your oil pressure sensor. There is a specific oil sending unit socket to change it.
Old 09-08-2007, 03:08 PM   #5
shiny alero
^^ yeah, probly what he said...
Old 09-08-2007, 03:16 PM   #6
yeah... i noticed.
argh.
Can be closed. I found it (its B) and you can get it off if you go easy on it with a 1 1/16th Deep well socket.
BOTH my gauges work now.
Old 09-14-2007, 10:20 AM   #7
before someone gets around to closing this...
i just was thinking...
should be my starter's connections really be that rusted?? that can't be good for conduction...
not to mention, i know our fuel pumps are kinda crappy along the lines of starting.... but my starter seems to not want to turn over well all the time. that a possible explanation?
Old 09-14-2007, 12:59 PM   #8
Knew it had to be B if not then they would'nt have a reason to charge an arm and leg if you were to take it to the shop. As far as the starter just clean it with terminal cleaner then coat it with protectant same stuff you use on the batter terminals, can't think of the names though. Somebody leth the man know.
Old 09-14-2007, 03:56 PM   #9
01silveralero
01silveralero's Avatar
shouldnt be that rusted up just clean it up with some terminal cleaner
Goal - Mid 11s all motor.
Old 09-14-2007, 05:32 PM   #10
i know the wire connectors are rusted pretty good. i might have to replace those... depending on how bad the contact side of them are...
Old 09-15-2007, 02:03 AM   #11
SIUlero
SIUlero's Avatar
SIUlero is on a distinguished road
it's cherry, I don't think he needs help with the name of dielectric grease...at least I hope he doesn't. anyway, i don't know that it would help much there, it would probably cook right off as hot as the starter can get. But definitely clean up the connections
SIUlero
'01 Alero GL
'72 Cutlass Supreme
http://www.cardomain.com/id/CrazyOldsGuy
SIUlero is offline   Reply With Quote
Old 02-24-2008, 05:18 PM   #12
Did the sending unit fit without any adapters?
I just put in my oil gauge today, but didn't hook up the sending unit. Not allow to work on the cars here after dark, plus I was hungry and tired. Worked on all 3 cars today
Old 02-24-2008, 06:00 PM   #13
no, i had to get a small adapter from napa. it was like $3... the stock sensor was larger then the aftermarket one.
