Old 09-19-2007, 06:41 PM   #1
Alero_1986
Alero_1986's Avatar
Alero_1986 is on a distinguished road
Reverse lights troubleshoot
My back-up lights are not comming on when I shift into reverse. I was wondering if anyone would have any advice on troubleshooting this issue? is there a switch/sensor on the shifter? or a fuse? I have a manual transmission. I checked the bulbs and they're fine. Any advice would help
thanks.
Alero_1986 is offline   Reply With Quote
Old 09-19-2007, 08:46 PM   #2
TurboAleroGT40
TurboAleroGT40's Avatar
TurboAleroGT40 is on a distinguished road
Check the fuse or, check the connecter on the tranny wire the shift cable is connected
TurboAleroGT40 is offline   Reply With Quote
Old 09-20-2007, 06:11 AM   #3
steve-o
Canadian... Eh?
steve-o's Avatar
steve-o is an unknown quantity at this point
Send a message via MSN to steve-o
I had that problem when I first got my ho, ended up being the reverse light switch, which can be found on the tranny. I went through two of them, one was broke when I get the car, and the new one I got I think must have been bad, because it only lasted a few months, the one I got now seems to be holding up ok.
But like said, check the easy things first: bulbs, fuses.
steve-o is offline   Reply With Quote
Old 10-31-2007, 12:39 AM   #4
Alero_1986
Alero_1986's Avatar
do you recall how much $ that switch is worth? Where is it located on the tranny? behind the shift cables?
