Old 04-18-2004, 09:47 AM   #1
hitokiri
I just purchased a pair of fog light bulbs that are blue for my 2000 alero gls. Does anyone know the procedure you go through to get get to the fog light bulbs to replace them. The headlights are easy but I don't know where to start with the fog lights.
-Hitokiri
Old 04-18-2004, 03:31 PM   #2
99blackalero
All you have to do is remove the headlights
- two clips you pull up on towards the back of the light, then wiggle the light out
- remove corner bulbs by turning them and pulling out and theres a clip you have to remove for the main lights too
- once this is done reach down till you reach the fog light, twist the bulb and remove and thats how you do it
Old 04-19-2004, 11:57 AM   #3
stevenjj
You can also remove the covers just under the fog lights and get to them that way. You'll have to get under the car, but you won't have to jack it up. That's how I did it. It took about 20 min but half of that was finding the bolts for the covers.
Hope that helps!
Old 05-07-2004, 07:34 PM   #4
01GLS
i just told the service guy at GM to change it while I was getting my oil change... they did it in no time, and at no extra charge...
Old 05-08-2004, 08:51 AM   #5
If you do it from the bottom, don't do it right after rain. You will get water in your eyes
