Old 10-12-2007, 11:00 AM   #1
Exit9alero
Exit9alero's Avatar
Exit9alero is on a distinguished road
Send a message via AIM to Exit9alero
Start up troubles! help
Hey guys how you been, well im really concerned for once with the car, i wake up its a chilly morning bout 60 degrees nothing out of the ordinary and i got to start the alero banger, when i turn the ignition and the car starts but shuts off with a cough, all the interior electrical works except for the RPM, Speed, thermostat and gasoline gauges soo im really concerned with it if any of you have any feed back please let me kno asap im desperate and you guys are my only hope her other wise its off to the rip off mechanic
Exit9alero is offline   Reply With Quote
Old 10-12-2007, 11:25 AM   #2
misslindseysue
MINIac
misslindseysue's Avatar
misslindseysue is an unknown quantity at this point
Send a message via AIM to misslindseysue
How old is the car? Have you ever replaced the battery?
misslindseysue is offline   Reply With Quote
Old 10-12-2007, 01:06 PM   #3
Exit9alero
Exit9alero's Avatar
its a 99 v6 and new battery bout like 5 months ago
Old 10-12-2007, 06:16 PM   #4
turtles_ride
Are you using the original key? Sometimes being worn down causes the security keypass to cut power to the fuel pump. I had this problem, switched to my spare key which had never been used, and it starts fine now.
Old 10-12-2007, 07:19 PM   #5
Midgear
on vacation
Sounds more like an electrical problem.. the gas and temp. gauges would still work even though his security trips.. id start checkin fuses and mabey the battery
Old 10-14-2007, 08:16 PM   #6
Exit9alero
Exit9alero's Avatar
yeah the temp n gas gauges didnt work but it jus started up 2day soo ill let you gus know waht it was
Old 10-14-2007, 08:42 PM   #7
TheEdgeofSanity
TheEdgeofSanity's Avatar
my gauges didn't work right when my battery was effed up. try checking to make sure the battery terminals aren't loose or corroded. otherwise, take ur battery for a load test to see if its dead.
2000 Chevrolet Malibu LS
