Old 04-19-2004, 01:03 PM   #1
dadirtybulldog
okay, here's my prob... between 60-80 mph the front left of my car shakes terribly... i have brand new tie rods, new bearings, i've had my tires rotated and balanced too... still shakes... could this be my rotor???? help please!
Old 04-19-2004, 01:51 PM   #2
Pimpalero03
does it do it when ur braking or just when ur crusing. if u have the brake down iven the slightest and its doing it, its prolly the rotors
Old 04-19-2004, 01:59 PM   #3
mlcroy20
What kind of tires do you have??? and how much wear is on them?
Old 04-19-2004, 03:48 PM   #4
dadirtybulldog
it shakes when braking and cruising... my alero has 105,000 miles on it and i've never changed the stock gm rotors... i'm thinking they could be the problem... i have Kumho Ecstas p225 50r16... pratically brand new....??????????????????????????????????????????? ?????????????????????
Old 04-19-2004, 05:22 PM   #5
CocoaAlero
Shaking while driving most likley is a balancing issue. Have the tech look for a possible bent wheel also, or out of round tire or tires.
Shaking while braking is from the rotors. It doesn't take much runnout on our rotors to make the petal pulsate when braking. Have them measured to see if they're too thin. Probably need to be replaced.
Old 04-19-2004, 05:41 PM   #6
bigd6983
sounds like the rotors, like he said have them measure, since you HAVE to replace them, Id say go with some cross drilled ones
Old 04-19-2004, 07:22 PM   #7
dadirtybulldog
let me clarify, when i say shake.... i mean the steering wheel shakes violently, as you can see i've tried to fix this many ways and nothing worked... the last time it was at the mechanic was for this same problem, i was driving it home and it started to shake so bad i had to pull over and park it..... the mechanic said that my lugs had broken off, out of five he said i had one left, shoot that sounds pretty dangerous, right?.... right.... i know tell me about it..... he said he fixed it... true... it did fix the shaking somewhat for a little while, but here i am again with the same freaking prob... as far as i can tell me lugs are fine... i simply hate having to rely on what the mech says.... he said he put all new lugs in, i can't tell, i just know on that tire i'm missing all the chrome lug nuts.... that sux bigtime...
Old 04-19-2004, 08:49 PM   #8
CocoaAlero
You may not want to hear this but, you may want to see someone else for a second oppinion(sp?).
Old 04-19-2004, 10:56 PM   #9
Pimpalero03
rotors man. i put off changing mine once cuz it was winter and if i was going 60ish and braked it was like holding a freakin vibrating steering wheel. it was horrible. change those rotors and my as well do brakes to since ur craps gonna be all torn apart and it will be sooo much nicer :thumbsup:
Old 04-19-2004, 11:10 PM   #10
vulgar
vulgar's Avatar
vulgar is an unknown quantity at this point
Send a message via AIM to vulgar Send a message via Yahoo to vulgar
if its doing this while not hitting the brake at higher speeds it can be the axle as we,,...i had to have mine replaced.
A.K.A. sepultribe66
the alero will be missed :o(, but I love the mazda6 :o)
vulgar is offline   Reply With Quote
Old 04-19-2004, 11:21 PM   #11
Voodosoup
You have 105,000 miles on the stock rotors??????
For you do an insane amount of highway driving?????
When my rotors were jacked up it only shook/shiddered when braking.
Sounds like you have something more serious. Especially if you're throwing lugs off.
Do yo uhave aftermakret wheels? Are they 5x115 or are they the 5x114.3's?
Old 04-20-2004, 05:34 PM   #12
AleroDownSouthGirl
Mine did shake bad after they fixed my car after an accident and I had to bring the car get diagnosed. I could feel the floorboard throughout the car shake and the gas pedal felt like it was gonna fly out, and the steering wheel did some shaking too. I had to get a new bearing and hub. Maybe a new wheel arm could help, too. Go get it diagnosed. Those are usually free....if not insurance covers it. Tell them u hit a duck or something...hehe.
Old 04-21-2004, 08:10 PM   #13
BLK03GXS
BLK03GXS's Avatar
check yeaman what voodoo said.. what wheels u got? thats not the brakes.. they wont shake like that when the brakes arent applyed...
Sounds like something more serious... what wheel is it ??
sounds more like a driveshaft, or wheel,.. not JUST the rotors for shizzle..... h34r:
Old 04-21-2004, 10:39 PM   #14
dadirtybulldog
this is the best advice i recieved...lol.... oh no!...... i hit a duck.... time to call the insurance company..... :thumbsup:
Old 04-21-2004, 10:42 PM   #15
dadirtybulldog
the tires are Kumho "ecsta" P225 50R16, and i have american eagle rims... i not sure if they're 5x115 or 5x114.3's..... it's only the one tire, it also pulls to the right....
Old 04-21-2004, 11:30 PM   #16
00alerogls
you might want to have you alignment checked too especially if it is pulling to the right. if the alignment is off really bad or something in the front end is really wore it can cause a vibration or pull.
Old 04-21-2004, 11:33 PM   #17
Final-Reality
My car was recently pulling to the left at freeway speeds. I had just had my steering rack and toe link replaced, so naturally I thought it was the alignment. Turns out, one of the wheel bearings was too tight? So it may be your wheel bearings...
Old 04-26-2004, 06:44 PM   #18
dadirtybulldog
i just had the wheel bearing replaced on that side...i'd say about six months ago.... car was doing it before then... something is definately screwed with that tire because my tire tread is wearing extremely fast, only one front right tire.... i don't know, i'm just afraid i'm gonna be driving somewhere and my tire's gonna fall off.
Old 04-26-2004, 06:46 PM   #19
dadirtybulldog
can someone tell me why it would shake at certain speed (between 60-80), then when i pass 80 it stops....????...
Old 04-27-2004, 01:55 AM   #20
StealthAlero
First off, forget the brakes, that's not your problem. It wouldn't just kick in at 60mph. And i don't think it is a bent rim, because you would feel that the whole time during driving aswell. Are you using any kind of spacers with your rims? Did you torque the rims down enough? Because that is probably the reason why your last 4 studs broke before. I would definitely have another mechanic check out the car. Second opinions matter!!!
