Old 10-30-2007, 09:51 PM   #1
DarkStar
DarkStar is an unknown quantity at this point
dual 2 ohm, or dual 4 ohm
So whats the difference? im buying a pair of 12 inch kicker L7's and i need to decide between the 2 and the 4 ohm.. what would i be better off with?
DarkStar is offline   Reply With Quote
Old 10-30-2007, 09:57 PM   #2
Stanl3yX
Stanl3yX is an unknown quantity at this point
Send a message via AIM to Stanl3yX Send a message via Yahoo to Stanl3yX
what kind of amp do you plan on using?
New and Want to MOD
I have 2000 Red Alero
2.4L Twin Cam with 15" Tires
Stanl3yX is offline   Reply With Quote
Old 10-30-2007, 10:10 PM   #3
DarkStar
Ill be running a 2 channel 900 watt kenwood amp http://www.woofersetc.com/index.cfm?...duct_ID=25 01
to each subwoofer.
Old 10-30-2007, 10:40 PM   #4
joserivas19
joserivas19's Avatar
joserivas19 is on a distinguished road
id go with the 4 ohm subs cuz if you get the 2 ohm subs and you dont wire the subs correctly, you will convert the 2 ohm subs into 1 ohm when you connect them to the amp and will eventually blow up the amp. i say this cuz i just did it a few months ago and had to get a kenwood 1800 watt 1 ohm stable amp to handle my 2 ohm subs.
joserivas19 is offline   Reply With Quote
Old 10-31-2007, 01:44 AM   #5
2 omh
Old 10-31-2007, 08:10 AM   #6
FrankTheTank
FrankTheTank's Avatar
FrankTheTank is an unknown quantity at this point
get the dual 2 ohm, and wire the voice coils for each one in series. if u get the dual 4 ohm, you'll never get the right impedance for those amps.
FrankTheTank is offline   Reply With Quote
Old 10-31-2007, 08:11 AM   #7
All depends on what you are looking to do. If you want a louder sub go with the dual two...this will enable you to wire them for 1ohm or you can wire them for 4ohm, just make sure you amps are 1ohm stable, then make sure you have the power for it cause if you are underpower you will kill you amp, and possibly damage your sub. With the dual 4 you can wire it for 2ohm or 8 but who uses 8 anyway so there you go, and you can play it decently with what you are running, but you still have to consider whether or not you are getting enough power to the amp. Hopes this helps I just didn't have time to elaborate!
Old 10-31-2007, 08:22 AM   #8
Here's a few wiring options
Two 2 ohm = 2ohm load
Attachment 3154
Two 2 ohm = 8ohm load
Attachment 3155
Two 4 ohm = 4ohm load
Attachment 3156
Old 10-31-2007, 09:23 AM   #9
So it looks like that amp is 2 ohm stable. So get the dual 4 ohm sub and wire it so it presents a 2 ohm load. That is if your gettting 2 amps, one for each sub, i think thats what you meant. if not, still get the 4 ohm, just wire it different.
Old 10-31-2007, 09:26 AM   #10
FrankTheTank
Attachment 3154
Attachment 3155
Attachment 3156
Ignore the 2 guys above my post, they are steering you down the wrong path.
since he is running 1 amp per sub, and each amp is only 4ohm stable, these guides wont help him.
What you need to do is this for each sub and amp combination:
Old 10-31-2007, 10:56 AM   #11
I didn't see the ending of his statement and thought he was using one amp. But misunderstandings happen, even though that amp says it is rated at 4 ohmn's it may very well run at a lower ohmn rating for example my amp is rated at 2 ohmn's stable but i have ran it at 1ohmn for extended periods of time with out any problem what so ever. I do agree with Frank that setup is the best for your application Good luck man
Old 11-01-2007, 05:01 PM   #12
DarkStar
ok, well i got them ordered, and the box is being finished, now i was just wondering if i should bridge the connections to the amp, would it make a difference?
Old 11-01-2007, 05:16 PM   #13
GoldStar611
GoldStar611 is on a distinguished road
FrankTheTank said it with his last post. Wire each DVC sub up into 4 ohms, just like the picture, and connect them to the bridged output on each amp and you're set.
GoldStar611 is offline   Reply With Quote
Old 11-01-2007, 06:21 PM   #14
FrankTheTank
this man is correct.
Old 11-01-2007, 07:24 PM   #15
1, theres no need to run anybody down.
2, your actually right. I was looking at the 2 ohm stable when 2 subs are ran to it, not bridged.
Old 11-01-2007, 09:51 PM   #16
FrankTheTank
i wasnt trying to put u down man, i was just tryin to make sure the guy knew your advice wasnt gonna work for him.
Old 11-01-2007, 10:26 PM   #17
^srry, it came off like that to me. o well, at least he got his question answered.
Old 11-04-2007, 05:48 PM   #18
All depends on the amp.
Only difference is wiring options.
