Old 11-11-2007, 06:50 PM   #1
Frostbite545
Frostbite545's Avatar
Frostbite545 is an unknown quantity at this point
Send a message via AIM to Frostbite545
Gauge Cluster Bezel
I guess this is appearance related...
Just got a polished stainless steel gauge bezel in. I'm waiting on the white gauge face covers (pics whenever I get em and they're installed). All I really need to know, is how to separate the clear plastic cover from the black plastic housing, which are, in effect glued together by Satan himself.
In the how to section, I found something that suggested using a (dremel?), but seeing as how i don't have one now, i was wondering if anyone had a suggestion or had tried to do this before. Thanks.
- (2000 GL) 14.748 @ 93.04
- Doctor Speed Cold Air Intake
- DHP PCM / 180* Tstat
- General Exclaim UHP Tires
- 2 1/2" Pacesetter Exhaust
- S&S Headers
Frostbite545 is offline   Reply With Quote
Old 11-11-2007, 06:59 PM   #2
when you take the gauges out it has snaps all around it. Thats pretty much all you need to undo to get to the clear part off. there might be one more thing to do (i havent taken my gauges apart for awhile) but its pretty simple once you get it out. and dont worry about losing a screw or two i only have two screws holding the gauges in now.
Old 11-11-2007, 07:08 PM   #3
Frostbite545
Oh I have the entire gauge cluster out, and unsnapped everything so I can put the gauge faces on. Its the clear plastic piece (the one that prevents someone from say... poking their gauge needles while in place lol) I need to remove thats like glued to the black stock bezel...
- S&S Headers
Old 11-11-2007, 07:51 PM   #4
ill take mine apart tonight. i know ive done it multiple times :\
Old 11-11-2007, 09:51 PM   #5
Frostbite545
Cool if you figure it out let me know. I'm more looking for what type of cutting tool of doom that I should employ..
- S&S Headers
Old 11-12-2007, 12:44 AM   #6
just use a little screw driver and a hammer and gently pound the two clear tabs up be careful taking out i cut my finger tonight
Old 11-12-2007, 11:56 AM   #7
TheMeaningOfLife
TheMeaningOfLife's Avatar
Mines glued on... Like really well.
Old 11-12-2007, 12:19 PM   #8
then. Before you pound the tabs up use a hair dryer on high around the glue..
Old 11-12-2007, 03:34 PM   #9
Frostbite545
alright then ill try that once I get home... Im just afraid
to break it
- S&S Headers
Old 11-12-2007, 04:26 PM   #10
just be gentle with it. take your time. naich installed silver bezel if i remember correctly give him a pm if youre really afraid.
