Old 04-21-2004, 11:30 PM   #1
jjkool
Under the dash on a 2 dr where can I find both constant and switched 12v power that I can tap off of?
Old 04-21-2004, 11:58 PM   #2
smokinAMD
Cigarette Lighter.
Old 04-22-2004, 03:11 AM   #3
jonez
use a toggle switch for the switchable power
Old 04-22-2004, 03:41 PM   #4
jjkool
I know that much B) but where can I find power that is switchable (through the ignition) ?
Old 04-22-2004, 07:13 PM   #5
niral622
niral622 is an unknown quantity at this point
isn't there switched power to the head unit? what are you trying to run with it? You might be better off using constant power and the remote/ant wire with a relay for anything big
2003 Black GL - Sedan and No sunroof
niral622 is offline   Reply With Quote
Old 04-22-2004, 10:04 PM   #6
brsexton
You can find both in the fuse box...Thats where I connect my FM modulator for my Mp3 player.
2005 Honda CR-V AWD
Old 05-15-2004, 04:46 PM   #7
Vtolds
H&B Shipping Agent
Vtolds's Avatar
I don't know what you are trying to hook up but to avoid any Wiring messups I would suggest just running new wire with fuse from battery to switch then to whatever you need it for weather it be fog lights or under body kit. :thumbsup: And don't forget get Grounding it
Old 05-15-2004, 07:12 PM   #8
MACBUYA
if your looking for something that has power when the key is on and is under the dash, i just tied into a wire off the heater controls.
Old 05-18-2004, 10:49 PM   #9
Aleromaster
Aleromaster is an unknown quantity at this point
Send a message via AIM to Aleromaster Send a message via Yahoo to Aleromaster
ignition driver side fuse, constant passenger side.
2002 GL2 4DR, MYMODS:In dash 7&quot; VGA Widescreen monitor, XM Satalite Radio, Clarion Amp, 2 10&quot; Audiobanhn DVC Subs Hidden HitchTrailer Hitch, Grill Mesh
Aleromaster is offline   Reply With Quote
