Old 11-23-2007, 09:54 AM   #1
modalero01
modalero01's Avatar
modalero01 is on a distinguished road
Send a message via MSN to modalero01
Help on wiring subs
Hi. i have a question for anyone who knows stuff about subs. i have 3 12" alpine Type e's that i put in a box for three and i want to connect it to one or 2 300 watt amps. how would i do the wiring for that. If not, how can i wire the 3 subs to a 2 channel 1000watt amp? have a diagram i foud but im not sure if its correct. any help? thanks! http://www.crutchfield.com/learningc...2Dohm%5Fmo no
modalero01 is offline   Reply With Quote
Old 11-25-2007, 09:49 PM   #2
StoopidAlero
StoopidAlero's Avatar
StoopidAlero is on a distinguished road
basically what you will need to do is figure out what the impedence is for your subs and if they are single or dual voice coil. Then figure out the lowest ohm rating is for your amp. From there.. you can basically get online and find a diagram that will specifically tell you how to wire your subs ( series or parallel.) I would have to check but im pretty sure there is a site where you can just put all your info into a calculator and it will give you the impedence and wiring suggestions.
StoopidAlero is offline   Reply With Quote
Old 11-27-2007, 09:02 PM   #3
tonkpils
tonkpils's Avatar
tonkpils is an unknown quantity at this point
Send a message via Yahoo to tonkpils
www.rockfordfosgate.com
they have a wiring diagram on there in the support part. good luck
Clarion VRX775VD
Eclipse 21010 Indash EQ
Zapco I 6.2 comps
Memphis M-Class 6x9's
Treo SSi 12.22 x 2
JL Audio A1800 on subs
JL Audio 300/4v2 on comps
Optima Yellowtop and Big 3 upgrade
tonkpils is offline   Reply With Quote
