11-27-2007, 11:22 PM
Shaking Trunk
Hey I just installed my subs and my trunk is rattling like a motha, what would be the best way to stop it
The part that is rattling is the little space above the word Alero.
11-27-2007, 11:26 PM
weather stripping works good. Just take that piece off and run weather stripping around the edge where it makes contact with the car and put it back on and there ya go. Also you will have to do the lince plate as well.
2003 Alero
2.2 5speed
Grey
1996 GMC Yukon 4x4
11-27-2007, 11:33 PM
i just used clear weatherproof silicone and no problems here
11-27-2007, 11:37 PM
when i had subs in the trunk and the plate on the truck i used expanding foam worked great used it on alot of vehicals
11-27-2007, 11:40 PM
I've used weather stripping behind the plate on my old car. Worked great.
11-27-2007, 11:58 PM
take the back picec off the trunk and use a whole crap load of weather stripping. helped mine a LOT.
11-28-2007, 12:07 AM
Boost Guru
Take the subs out
11-28-2007, 01:03 AM
where the top license plate screws are i drilled into the trunk and ran carrage bolts through and thightned them with wing nuts. they don't come loose and no one can tell and it works
01 Alero GX 3400 swapped
v8 swapped 84 s10
11-28-2007, 08:22 AM
Originally Posted by Spilner521
Take the subs out
it would be better for your hearing....trust me.
2003 Alero
2.2 5speed
Grey
1996 GMC Yukon 4x4
11-28-2007, 10:57 AM
Thread Crapper
dang, i thought i was being clever using weather stripping.
i used the stuff that is sticky on one side.
put it around my tail lights and any other place i could squeeze it into.
works great.
