12-12-2007, 10:04 AM
Weak Brakes
I know its not the hardware.... i just changed my rotors/pads about 2.5 years ago. (only like 10k miles) so they are still great condition.
but what would cause my brake distance to increase? i was going like 60 today and when i noticed i wasn't gonna make the light, i broke like usual, and noticed it wasn't slowing down a hell of alot. (roads were a little wet, but nothing slide worthy) my usual brake distance was like half what it was today, which makes me worry some. I know some is attributed to bad judgement. pharmacology exams shouldn't be allowed at 8am.
i DID just get winter tires.. but that shouldn't matter.
I have had time to check my brake fluid, but i haven't noticed any leaking, so that should be fine too.
I'm only at like 54k miles, could my drums/shoes be dead already? and if not, how would i go about tightening up my brakes, making my pedal a little more responsive?
12-12-2007, 10:33 AM
So there is a lot of play in the pedal?
12-12-2007, 10:46 AM
[english lesson] that's not the proper past tense of brake, should be braked. [/english lesson]
try bleeding the lines maybe?
12-12-2007, 10:49 AM
there isn't a tremendous alot of play in the pedal, if i step on it slightly it does brake slightly, but it seems like the whole middle ground of "more pressure = quicker stopping" isn't quite there.
and thanks for the english lesson there....
12-12-2007, 10:50 AM
See if you can get the brake fluid tested. Brake fluid is usually only good for 5 years before needing replacement. My dealer tested mine and it is starting to weaken so a brake flush and replace is in order for my car.
??,??? km
??,??? miles
12-12-2007, 10:59 AM
well if you havent flushed/bled your brake fluid now might be a good time to do it
12-12-2007, 12:18 PM
well... i know it hasn't been changed since i got it (and probably not before that) and the car is nearly 5 years old. hmm...
how would i go about doing that? or is it better to pay for it, and have it done "right" the first time?
12-12-2007, 06:25 PM
I'm going to get the dealer to do mine. $90 isn't a lot for a complete flush and fill.
??,??? km
??,??? miles
12-12-2007, 07:06 PM
yea meineke or a deal will charge you just under $100 for a full flush
12-14-2007, 09:40 PM
And it's worth it. Without a good one-man bleeding kit like the MityVac, bleeding is pretty tedious.
A MityVac will run about $35, so you're almost halfway toward having somone else do it.
However, if you do decide to tackle it, get a GOOD six point flare nut wrench for the bleeder screws. The screws are soft and the hex is easily stripped.
12-14-2007, 10:11 PM
^ at that rate, it wouldn't be worth it at all.... i'll look into getting it done over winter break.
