Old 04-24-2004, 11:28 PM   #1
Oldsman
Owner
Oldsman's Avatar
In your installation manual you will be mostly dealing with the diagram on page 11, figure 11. To get to this on the car you must first remove the IDI cover on your motor (the part with 2.4L Twin Cam written on it).
Under that you will have a white ignition tower and a black and silver square looking module. Remove the tower from the IDI cover and you will see your coils. The wires between the square module "Power train control module" and your coils are the ones you will be cutting.
Just a suggestion....mark one of the white wires with a dot so you don't have to remember which one is which!
There is one brown wire which is your "ignition 12 volts", and 2 white wires which are your "triggers". What I did to tell them apart is to look at the bottom diagram on page 11, coming from your coil harness the far left wire is your brown wire "ignition 12 volts", the second wire over on both the diagram and the harness is your trigger 1, and the last one on the far right is your trigger 2.
Drill a hole in the side of the white tower case for the wires to go into the white tower.
On the square module/plug side of the wires: Connect the 2 red MSD wires to the brown "ignition 12 volts" wire on the plug. Connect the white MSD wire to the middle white "trigger 1" wire. Connect the green MSD wire to the other white "trigger 2" wire.
On the coil side of the wires: Connect the 2 brown/orange MSD wires to the brown "coil (+)" wire going to the coils. Connect the brown/white MSD wire to the middle white "coil (-) trigger 1" wire. Connect the remaining brown/green MSD wire to the remaining white "coil (-) trigger 2" wire.
All your have left to do is mount your DIS II box and to wire your pos and negative to the battery, and the theft deterrent and staging rev limiter if you decide to run them, otherwise cap them off and they will be fine.
Switch settings
N/A setup
SW1: S1-OFF, S2-OFF, S3-OFF, S4-ON, S5-OFF, S6-ON, S7-ON, S8-ON
SW2: ALL OFF
SW3: S1-ON, S2-OFF, S3-ON, S4-OFF, S5-ON, S6-OFF, S7-OFF, S8-OFF
Nitrous setups
2 degrees retard, for up to 50-hp shots
SW2: S1-OFF, S2-OFF, S3-OFF, S4-OFF, S5-OFF, S6-ON, S7-OFF, S8-OFF
4 degrees retard, for 50-HP to 100-hp shots
SW2: S1-OFF, S2-OFF, S3-OFF, S4-OFF, S5-OFF, S6-OFF, S7-ON, S8-OFF
Beware of the BackStabber
Old 04-24-2004, 11:29 PM   #2
Oldsman
Owner
Oldsman's Avatar
now for pics..........
Old 04-24-2004, 11:29 PM   #3
Oldsman
Owner
Oldsman's Avatar
another
Old 04-24-2004, 11:30 PM   #4
Oldsman
Owner
Oldsman's Avatar
all together on IDI cover
Old 04-24-2004, 11:31 PM   #5
Oldsman
Owner
Oldsman's Avatar
the tear down
Old 04-24-2004, 11:32 PM   #6
Oldsman
Owner
Oldsman's Avatar
mounting the MSD
Old 04-24-2004, 11:33 PM   #7
Oldsman
Owner
Oldsman's Avatar
all finished installed
