Old 12-21-2007, 02:01 AM   #1
Intercooler /Intake system
Originally Posted by rowdygls View Post
Welcome
I'm interested in that intercooler and under hood pics would be good as well.
Here it is at present time. the wrapped section is all one welded piece, 2 1/2 in. outside diameter, and going into the IM is 2 1/2 in. inside diameter.
Old 12-21-2007, 02:04 AM   #2
umm wow no room at all in that mofo....
andim confused with al the pipes
Old 12-21-2007, 03:55 AM   #3
LOL, that is pretty messy dude!
Old 12-21-2007, 06:34 AM   #4
wow nice
do you fill the box with dry ice at the track ?
Old 12-21-2007, 09:03 AM   #5
rowdygls
rowdygls is an unknown quantity at this point
Send a message via AIM to rowdygls Send a message via MSN to rowdygls Send a message via Yahoo to rowdygls
Is that intercooler readily available or is a custom job ??
I have a M62 as well and this is something I would be interested in picking up.
Thanks.
my cardomain: http://www.cardomain.com/ride/605233Alero
Chapter Member
rowdygls is offline   Reply With Quote
Old 12-21-2007, 09:19 AM   #6
01silveralero
01silveralero's Avatar
x2..........
Goal - Mid 11s all motor.
Old 12-21-2007, 10:13 AM   #7
Thanks.
Sorry about the ugly pics, it's that darn digital camera--too much resolution
You can get the cores, assemblys, etc. here:
http://www.turboneticsinc.com/produc...category_id=10
I will be discussing design considerations as time allows, but keep in mind that the setup is constantly changing, and those parts are being re-used and abused!
Old 12-21-2007, 10:25 AM   #8
hok666
hok666 is an unknown quantity at this point
OMG I just bust a nut..........
NICE PICS
hok666 is offline   Reply With Quote
Old 12-25-2007, 10:28 PM   #9
Cai
The filter is a K&N #1796, 6 X 9.5 in.
The headlight mount is separated into two pieces for easier access, and a sheet of rubber sits above the filter as a rain shield. The tubing is 3 in., but needs to be upgraded to 3 1/2 in.
Old 12-25-2007, 11:16 PM   #10
lol that would be the intercooler.. not an icebox
Old 12-26-2007, 06:34 PM   #11
mike2002
mike2002 is an unknown quantity at this point
Send a message via Yahoo to mike2002
is that the gm m62 kit? that there are only a few of?
2001 Alero GLS - Sold!
mike2002 is offline   Reply With Quote
Old 12-26-2007, 08:30 PM   #12
Really nice set-up man
Old 12-27-2007, 12:27 AM   #13
Yeah, it's one of the Gen-4 kits, with the key components being the internal bypass valve and rising rate FPR. When I called Magnuson tech about a month ago, the guy said you can still special order the supercharger/driveshaft combo, minus the inlet and outlet ducts, for "around $2000.00" for an M90, maybe less for the M62. But you better be sure of the drive length you specify.
Old 12-27-2007, 01:51 AM   #14
wow nice
The system uses a 3 gallon reservoir tank (actually a fuel cell). For racing, icewater is used in the tank, heavy on the ice.
Old 12-27-2007, 06:20 AM   #15
i believe 17 is the number........
Old 12-27-2007, 04:17 PM   #16
Spilner521
Boost Guru
Spilner521's Avatar
Nice setup. Where'd you pick up the carbon fiber tube?
Old 12-27-2007, 07:46 PM   #17
i'm pretty sure he hand made it......just like his carbon fiber scoop
Old 12-30-2007, 03:29 AM   #18
"Hand made" sounds good. The truth is, I messed up the project every way you can think of, but still managed to come up with a good functional part. I used styrofoam to form the inside shape of the tube, then laid the carbon fiber around it, and extracted the styrofoam after it cured ("sacrificial mold"). The original idea was to use all Kevlar fiber, but I forgot to buy the special shears needed to cut it. Then I ran out of carbon fiber and still had to use the one Kevlar strip. Worst of all, I didn't use mold release compound, so a lot of sanding had to be done on the inside. A similar piece needs to be constructed to connect down through into the filter area.
Old 12-30-2007, 03:44 AM   #19
IM Detail
