Old 04-26-2004, 04:24 PM   #1
b-spot
b-spot is an unknown quantity at this point
Hey Audio experts,
Just got a new HU, and the subs fire way louder off of my old highpass install compared to now that i'm runnin RCA's back from the deck. I had to turn up the bass eq on the amp to get it back close to the way it was.
Is this normal?? :huh?:
If I did went to college...
b-spot is offline   Reply With Quote
Old 04-26-2004, 04:50 PM   #2
Cyber Knight
Swank
Cyber Knight's Avatar
Do you mean high level inputs (off a speaker lead) vs low level inputs (from the RCAs)? Were you using a line level converter or does your amp take both types of inputs?
Old 04-26-2004, 05:01 PM   #3
b-spot
Yeah, high pass= running off of speaker level inputs. And my amp takes both, so I was able to compare the high pass to the RCA in off of the same deck.
thx.
Old 04-26-2004, 05:31 PM   #4
bigd6983
I dont know what to tell you on that, is the sound cleaner?? what kinda of HU do you have now?? what kind was your old one or was it stock?? you should definately be able to tell the difference unless your new HU has low voltage on your pre outs
Old 04-26-2004, 06:04 PM   #5
Cyber Knight
Swank
Most new decks have faily high voltage pre-outs so that shouldn't be a problem. I've never tried both inputs on the same amp and compared the 2, now I'm curious too.
Old 04-26-2004, 06:13 PM   #6
b-spot
The highpass sounded similar from the old deck (stock) to the new deck (Alpine CDA-9827)
The difference is just between high pass/RCA with the same deck.... and yeah, it does sound WAY cleaner with the new deck.
Old 04-26-2004, 06:54 PM   #7
Travis99Alero
sounds like you dont have a subout on your deck, you're just using either the front or rear output.
Old 04-26-2004, 06:55 PM   #8
99blackalero
if you have a sub-level out on your alpine deck B, check the sub-level on the deck
Old 04-26-2004, 07:00 PM   #9
99blackalero
press the volume knob to access sub level, fader, balance
Old 04-26-2004, 09:41 PM   #10
boarder211
Dunno much about the Alpine HU's, but my Kenwood HU has and adjustable sub-out. I was messing around one day when I was driving, and found that there's an adjustment for the voltage output of thr RCA's... crank that baby and watch the car shake!
Old 04-26-2004, 10:15 PM   #11
99blackalero
the level on the alpine goes from 0 - 15...so if its at 0, then that would explain why it didnt sound as loud
Old 04-27-2004, 11:00 AM   #12
b-spot
Thanks for the replies guys, yes it has a sub out (4v) as well as front and rear preouts. I'm positive its plugged into the right one.
Sub level is at 15 (max).
hmm...
