Old 12-31-2007, 05:32 PM   #1
AJules
AJules's Avatar
AJules is on a distinguished road
How do I get my rear speakers out?
yeah, self explanatory
I searched, different people said different things
I tried the haynes manual way and it can't be right.
so yeah, how do I do it?
AJules is offline   Reply With Quote
Old 12-31-2007, 05:40 PM   #2
Vinman
Vinman's Avatar
Vinman is on a distinguished road
Send a message via AIM to Vinman Send a message via Yahoo to Vinman
its super easy..all you do is gently pry up on the speaker grills, they should pop and i believe you pull towards you and up, then (its easier if the seats are folded down)if you look under the deck you should see a large clip hanging from the top by where your speakers are...those are the brackets, just squeeze the clip and push up and the speaker is free, and they are removed from the top...and if you're replacing with other 6x9's i think you can still use the factory bracket so you don't have any vibration issues...I'm still yet to do this myself...and to get the old speakers off the bracket, carefully pry on the plastic tabs, if you get two free, then the speaker should be wiggled or whatever free....I hope this helps..
Note: and I stress carefully and gently prying
Vinman is offline   Reply With Quote
Old 12-31-2007, 05:48 PM   #3
AJules
AJules's Avatar
okay thanks I'm gonna try that right now
Old 12-31-2007, 06:13 PM   #4
AJules
AJules's Avatar
wow, it worked exactly how you said it would
thanks so much
Old 12-31-2007, 06:52 PM   #5
AftermathAlero
The 99-00 speaker grill on the rear deck don't pry out. Just need to clarify
Old 12-31-2007, 06:56 PM   #6
yeah i was wondering there lol. i had to pull the whole rear deck
Old 12-31-2007, 07:13 PM   #7
AJules
AJules's Avatar
mine is a 99 and it came right out
Old 12-31-2007, 08:00 PM   #8
just the plastic grille part that goes right above the speakers? not the whole carpeted piece including the plastic grille?
Old 01-01-2008, 12:57 AM   #9
just as easy (and less likely to break something) if you take the rear deck out. and if your planning subs, put something under the deck so it doesn't vibrate as much.
Old 01-01-2008, 01:24 AM   #10
AJules
AJules's Avatar
yepp, all I hadta take out were those
nothin else
then the speakers came right up
Old 01-01-2008, 01:51 AM   #11
Vinman
Vinman's Avatar
yeah, when i did my rear speakers,i only took off the plastic grills and didn't touch the carpeted deck. and i have a 99 coupe
Old 01-01-2008, 02:06 AM   #12
AftermathAlero
i know my sedan 4dr grill doesn't come out... it plastic rivited to the carpet rear deck.
Old 01-01-2008, 09:49 AM   #13
Vtolds
H&B Shipping Agent
Vtolds's Avatar
I thought in my 2000 they were riveted down or something because when I wanted to give a better look at them one day I had to remove the whole rear deck which was very eay too.
Old 01-13-2008, 06:42 PM   #14
yeaaaaa. i tried yesterday and the plastic part doesnt just pop out that easy. I even tried using a screwdriver and still no luck. That plastic peice is ANNOYING, it vibrates like crazy.
Old 01-13-2008, 08:17 PM   #15
nickbain
nickbain's Avatar
nickbain is on a distinguished road
turn down the music lol
2003 Alero
2.2 5speed
Grey
1996 GMC Yukon 4x4
nickbain is offline   Reply With Quote
Old 01-13-2008, 10:15 PM   #16
AJules
AJules's Avatar
you're probably going to have to take out the whole rear deck
theres some old threads on doing it
but for a quick fix, why not put something inbetween there for now so it doesn't have anything to vibrate against?
Old 01-15-2008, 06:39 PM   #17
what do you mean put something between there????
I thought i could just go buy some dynamat and put it under the rear deck.....but then it would still make the rattling because the cover is right over the speaker, and i cant cover the speaker any suggestions?????
Old 01-15-2008, 10:37 PM   #18
AJules
AJules's Avatar
nevermind, your speaker covers must not be like mine
if they were, they would be pretty easy to unclip and take out
Old 01-16-2008, 12:23 AM   #19
yea, they dont come out easy. there are 2 clips under it, but i tried prying it up after i pushed the clips in and it still wouldnt come out....... gayyyy
Old 01-16-2008, 07:09 PM   #20
Grow some hair and pull
