Old 01-16-2008, 11:40 PM   #1
02Alero
02Alero's Avatar
02Alero is on a distinguished road
Send a message via AIM to 02Alero
trac off light and anti-lock lights on
my SVS light, trac off light, and my anti-lock lights came on at the same time; has any had this problem.
02Alero is offline   Reply With Quote
Old 01-16-2008, 11:47 PM   #2
AftermathAlero
yes , we all have. its your wheel hub. Get someone to scan the code for you to locate which wheel its coming from. A normal scanner would not work. You need a shop w/ a good expensive scanner that can read ABS brake codes. Not an engine code scanner.
Old 01-16-2008, 11:51 PM   #3
02Alero
02Alero's Avatar
thanks how much does that usually cost to fix and is my car safe to drive
Old 01-17-2008, 12:13 AM   #4
Oldsman
Owner
Oldsman's Avatar
if you do it yourself...........$100-$150
Beware of the BackStabber
Old 01-17-2008, 01:32 AM   #5
Mr_Reed
Mr_Reed's Avatar
Mr_Reed is on a distinguished road
Send a message via AIM to Mr_Reed
If the dealer ship does it about 400
Live to Ride
Ride to Die
Mr_Reed is offline   Reply With Quote
Old 01-17-2008, 04:22 PM   #6
And I've been driving on it since i've bought the car... In june... But I only have the Sensor itself gone... Listen up for any noises from the Bearing and whatnot.
