Old 04-28-2004, 12:50 AM   #1
j{}n
j{}n's Avatar
j{}n is an unknown quantity at this point
Send a message via AIM to j{}n Send a message via MSN to j{}n
Arrow
well, here's a list of problems with the 'hoe:
1. grinding noise whenever i drive, kind of similar to when your brakes are completely shot, only it's constant, and really frikkin loud
2. occasionally it'll sound like i ran over a coffee can, making a clanking noise
3. grinding/growling noise whenever i turn, especially to the right (tires do rub a lil)
4. my nighttime interior lights won't come on. the gauge cluster functions
normally, but none of the nighttime lights come on
5. occasionally when i go around turns it feels like my front wheels are going to fall off (this happened before, i definitely know the feeling)
well, open game fellas. i think the grinding is the wheel bearing, the grinding/growling is the power steering, and the clanking is the cvjoint boot or whatever the hell it's called. the nighttime lights thing i'm still scratching my head over. any help is appreciated
'05 mazda 3
zoom zoom biatch
j{}n is offline   Reply With Quote
Old 04-28-2004, 04:08 PM   #2
j{}n
j{}n's Avatar
oh, and now my "anti-lock brakes" and "trac off" lights come on and won't turn off
'05 mazda 3
zoom zoom biatch
Old 04-28-2004, 05:02 PM   #3
trickalero
jack it up...pull the front wheels off and you might be able to see what the problem is with all the front end poop that is happening. grab your brake disk and see if it wiggles.if it does.....then there is one problem.also check your brake pads. mine make a loud anoying noise all the time when the brake pad got low enough that the "tadle tail" rubbed on it all the time . both my front calipers were sticking so it wore out the one side of my brake pads instead of wearing evenly on both sides. :thumbsup:
Old 04-28-2004, 05:04 PM   #4
trickalero
oh and if your car grinds or make anykind of noise like that when you turn your wheels all the way to either side than your cv joints are probably hooped.
Old 04-28-2004, 06:37 PM   #5
scotttherock
yeah i have the same problem since i installed my gauges...its been like this for a few months now...im use 2 it being really dark in my car at night..i even know all the radio buttons by heart and where they r so i dont need any light...but neway does ne1 know how 2 fix this problem?
Old 04-28-2004, 08:30 PM   #6
vulgar
vulgar's Avatar
vulgar is an unknown quantity at this point
Send a message via AIM to vulgar Send a message via Yahoo to vulgar
^id start by checking the fuses.
A.K.A. sepultribe66
the alero will be missed :o(, but I love the mazda6 :o)
vulgar is offline   Reply With Quote
Old 04-28-2004, 08:59 PM   #7
j{}n
j{}n's Avatar
i've yanked every fuse; driver's side, passenger's side, and under the hood. all of em are fine. could it be that the part that "senses" light and dark is shot?
'05 mazda 3
zoom zoom biatch
Old 04-28-2004, 09:04 PM   #8
3.4Alero
/\ /\ Have you tried actually switching on your headlights? Instead of relying on the sensor. It may sound dumb, but you DID check your dimmer didn't you? Make sure it's not turned down all the way.
For the ABS and trac off, that confirms you have at least one bad hub.
Old 04-28-2004, 10:10 PM   #9
ptrudel
Designated Drunk
bad hub is definately one problem
I'm baaaackk
Old 04-29-2004, 03:48 PM   #10
j{}n
j{}n's Avatar
yeah, i checked the dimmer and tried manually switching the lights on and off. didn't work. anyway, how hard is the hub to replace? i haven't really messed with much in that region. idea of cost? oh yeah, it's progressed to a consistant clanking, which gets louder when i turn right. does that shed any light?
'05 mazda 3
zoom zoom biatch
Old 05-05-2004, 06:16 PM   #11
zyklor
It seems I have some of the same problems
2. occasionally it'll sound like I ran over a coffee can, making a clanking noise
Problem 1 may be the bearing. Problem 2 and 5 happen to me too but I can't figure out why. Problem 3... I have no clue. Problem 4 may be that your dimmer switch is bad. I would try replacing the switch.
As for the anti-lock brake and trac off light being on, I had that problem and it was the ABS sensor in the front right. To replace the sensor you have the replace the entire hub assembly (also includes the bearing). That part, if I remember right, is about $170, $250 installed. You may be able to find it cheaper and install it yourself if you can. In any case, have your ABS system scanned for codes and that will tell you if and what sensor is bad.
Old 05-06-2004, 12:32 AM   #12
j{}n
j{}n's Avatar
got it all fixed today. i didn't really have much of a bearing to speak of... it was ground to poop. replaced brakes. the abs and trac off light are gone, and i've bought three dimmer switches, none work. who knows what the hell it is
'05 mazda 3
zoom zoom biatch
Old 05-06-2004, 12:35 AM   #13
j{}n
j{}n's Avatar
i think i need to add power steering fluid, that may get rid of the growling/whining
'05 mazda 3
zoom zoom biatch
