Old 01-25-2008, 01:56 PM   #1
dbailey
dbailey is an unknown quantity at this point
Question Proper Torque for Front Hub/Bearing???
I have heard that a TSB came out changing the torque requirement on the axle nut and bolts that hold the hub on. Does anybody know what those new numbers are? I do know that if you don't get them right that it leads to premature failure of the hub/bearing assembly. Thanks.
dbailey is offline   Reply With Quote
Old 01-25-2008, 05:39 PM   #2
vikz99
vikz99 is on a distinguished road
Dont know if this is going to help, but ill just put up the instructions of how the remove and install the wheel/hub assembly. Hopefully they're different torque specs than the ones you have! Good luck!
Removal & Installation
Front
To Remove:
Raise and safely support the vehicle.
NOTE:The front wheel bearings are not serviced separately. If the front wheel bearings are defective, the hub and bearing assembly must be replaced.
Lubricate the threads on the halfshaft with clean engine oil.
Remove or disconnect the following:
Front wheels
Halfshaft hub nut
Caliper from the steering knuckle
Brake rotor
Anti-lock Brake System (ABS) sensor from the backing plate
Hub and bearing assembly from the backing plate
Hub and bearing assembly from the halfshaft
To Install:
Install or connect the following:
Hub and bearing assembly onto the halfshaft
Hub and bearing assembly to the backing plate. Tighten the 3 bolts alternately and evenly to 70 ft lbs (95 Nm).
ABS sensor
Brake rotor
Caliper on the steering knuckle.
Halfshaft nut. Tighten it to 284 ft lbs (385 Nm) if the nut is black or 173 ft lbs (235 Nm) if the nut is gray.
Front wheel. Tighten the nuts to 100 ft lbs (140 Nm).
Lower the vehicle.
Rear With Disc Brakes
To Remove:
Raise and support the vehicle.
Remove the tire and wheel assembly.
Remove the brake rotor.
Disconnect the parking brake cable from the parking brake lever.
Disconnect the wheel speed sensor harness.
Remove the wheel hub assembly mounting bolts.
Remove the wheel hub assembly from the knuckle.
Remove the mounting bolts from the rear of the wheel hub assembly.
Remove the wheel hub assembly from the backing plate.
To Install:
Install the wheel hub assembly to the backing plate.
Install the mounting bolts to the rear of the wheel hub assembly.
Tighten the bolts to 89 in lb (10 Nm).
Install the wheel hub assembly to the knuckle.
Tighten the bolts to 70 ft lb (95 Nm).
Connect the wheel speed sensor harness.
Connect the parking brake cable to the parking brake lever.
Install the brake rotor.
Install the tire and wheel assembly.
Lower the vehicle.
With Drum Brakes
To Remove:
Remove the tire and wheel assemblies.
Remove the brake drum.
Disconnect the rear ABS wheel speed sensor wire connector.
Remove the bolts from the wheel bearing/hub assembly.
Remove the hub and bearing assembly from the vehicle.
To Install:
Install the wheel bearing and hub assembly on the steering knuckle.
Tighten the bolts to 62 ft lb (85 Nm).
Connect the rear ABS wheel speed sensor wire connector.
Install the brake drum.
Lower the vehicle.
vikz99 is offline   Reply With Quote
Old 01-25-2008, 07:27 PM   #3
dbailey
Thanks!
Old 03-15-2008, 08:49 AM   #4
Also note for the Axle nut you can use an 1 3/8" Deep Well socket or a 35mm Deep Well socket.
I used the 35 mm.
Old 05-06-2008, 11:03 AM   #5
JerzeyBoy
JerzeyBoy's Avatar
JerzeyBoy is on a distinguished road
what about gx?
i have a 2004 gx with NO ANTI LOCK BRAKES will it be the same set up as the instructions you have given?
2.2 Ecotec
4 door gx
plain and simple STOCK EVERYTHING
except for a air freshener
saving money like everyone else for future
mods
JerzeyBoy is offline   Reply With Quote
Old 05-06-2008, 11:16 AM   #6
surreal_awakening
surreal_awakening's Avatar
Note that this involves a redesigned hub nut. The old style nut, which had a sheetmetal shield around the nut, was torqued to 284 ft lbs. The new style nut does not have the sheetmetal shield around it and torques to 173 ft lbs. Not sure how relevant the color is. I think it may be more about whether or not you have the shield around the nut.
Old 05-06-2008, 12:06 PM   #7
Thanks for that piece of knowledge.
I have the old nuts...
I will be stopping by the dealer today to get the updated ones, if I can afford them.
Old 05-06-2008, 12:08 PM   #8
My nuts are pretty old now....LOL!
Old 05-06-2008, 02:30 PM   #9
surreal_awakening
AAP has them listed at $3.99 ea., and the picture appears to be the new style, but take that for what it's worth
Old 05-06-2008, 06:11 PM   #10
WTH is AAP?
Advance Auto Parts?
Old 05-06-2008, 06:14 PM   #11
01silveralero
01silveralero's Avatar
im pretty sure he is talking about advance auto parts
Goal - Mid 11s all motor.
Old 05-06-2008, 06:55 PM   #12
surreal_awakening
yeah...advance auto parts
