Old 01-26-2008, 01:47 PM   #1
Danny Boy
Danny Boy is on a distinguished road
Keyless Entry?
I just ordered a keyless entry from ebay, any body have a possible tutorial? bulldog security was great with the color wire diagrams but do I have to do any soldering? or any relays or anything? am i just basically splicing into the correct wires ? any help would be great thanks a million in advance!
Danny Boy is offline   Reply With Quote
Old 01-26-2008, 02:05 PM   #2
Yep, just splicing.
The wiring diagram site I posted a while back will help immensely.
You're going to need a 1500 Ohm resistor, since our cars use a 1 wire lock/unlock system.
Old 01-26-2008, 02:09 PM   #3
Danny Boy
oaky thats not a problem, lets say i get the 1500 ohm resistor and tap into the 1 wire lock/unlock, is there any other resistors or relays involved?
Old 01-26-2008, 03:55 PM   #4
nope
it's a white wire in the driver's side kick panel, run the wire that's unlock to the white wire with a 1.5k Ohm resistor to it and tap splice into it. run the wire that's lock to the wire and tap splice into it.
it may be reversed you'll have to look it up i forgot which is resisted
Old 01-26-2008, 03:59 PM   #5
I just realized your from Detroit, nice! I'm close by. Come to ASS '08 or die.
Wiring Diagrams: http://64.85.6.118/diagrams/diagrams.asp
"this vehicle uses a 1-Wire Door Locking System, LOCK requires a Straight (-)Negative and UNLOCK requires a (-)Negative thru a 1500 Ohm Resistor"
Dual stage lock/unlock will be harder. Mine's plain and simple.
Old 01-26-2008, 04:04 PM   #6
Danny Boy
ya all def try, thanks so much for your help, all let you know if i have anymore additional questions you've been very helpful!
