02-15-2008, 07:59 PM
Sloppy shifting - will the B&M Shiftplus help?
I have a 2000 Alero 3.4L with a sloppy shifting trans, especially the 1-2 shift. Will the B&M Shiftplus help that? The B&M model number is 70380 right?
02-15-2008, 08:13 PM
Trying To Help
yes right part number what do you mean by sloppy shift? more info please
03 OLDS ALERO
02-15-2008, 08:34 PM
Boost Guru
Oh yes, it'll help stiffen those shifts right up. You feel an immediate difference, seriously. It's one of the better mods I've ever done to my car.
02-15-2008, 10:39 PM
New and Improved
spilner did you get the stage 1 or stage 2? and how tough of an install was it?
02-15-2008, 11:17 PM
this is the next mod on my list
02-16-2008, 12:01 AM
I'm pretty sure it comes with a switch so you can toggle between
OFF
I
II
02-16-2008, 12:02 AM
New and Improved
yea i just re-read that... haha. i should have rephr********* it to which mode did he drive it in
02-16-2008, 01:46 AM
its for the 3.4?
02-16-2008, 01:54 AM
Owner
it works on the 4t40 and 4t45
Beware of the BackStabber
02-16-2008, 04:19 AM
Lucas. made the tranny in my wagon last two month until it went BOOM! then it didn't work. Get your tranny flushed and then get Lucas put in it. it will shift better... ...i hope
01 Alero GX 3400 swapped
v8 swapped 84 s10
02-16-2008, 07:09 AM
Takes a long time for 1-2 shift sometimes, especially at high RPMs.
02-16-2008, 08:23 AM
Trying To Help
installed said part number (70380) on 03 3400
my shifts are so fast they are scary compared to stock
03 OLDS ALERO
02-16-2008, 10:24 AM
So where can I get this?
Live to Ride
Ride to Die
02-16-2008, 10:36 AM
Trying To Help
summit racing, jegs, ebay maybe even jcwhintney
03 OLDS ALERO
02-16-2008, 10:52 AM
If you get the DHP PCM, you can't use this
02-16-2008, 02:06 PM
Trying To Help
03 OLDS ALERO
02-16-2008, 10:26 PM
Somebody here said something about having to turn the Shiftplus off and on all the time but I can't find the post. Can't you just install it and leave it on, say in position 1?
02-16-2008, 11:11 PM
Yes, you can leave it on position 1 all the time, but be advised it will accelerate the wear on your transmission oil pump.
The B&M ShiftPlus (and the AutoTrans Interceptor) both work on the same principle - they increase the current to the shift solenoids. If you wanted to modify the same thing in the PCM, it is the Force Motor Table.....which DHP doesn't make available to us (IDK if HPTuners does), because it can be so hard on the tranny. Use sparingly.
02-16-2008, 11:49 PM
Boost Guru
I've had my Shiftplus on my car for over 3 years, 2 of them turbo'd, and I've left it on setting 2 the entire 3+ years without any problems. Still shifts very fast and there's been zero transmission problems.
02-16-2008, 11:52 PM
Yeah, I've had it on a GMC Jimmy (one of it's intended applications) for like 7 years or so with no adverse effects as well.
