Old 03-05-2008, 12:28 PM   #1
zoL
zoL's Avatar
zoL is on a distinguished road
Wheel...wheel well.
So my punk ass wheels started rubbing against my front wheel wells... eff do I do? Springs are dead? Struts are dead? Am I effed? This just started like a week or so ago.
"If the author of the Declaration of Independence were to utter such a sentiment today, the Post Office Department could exclude him from the mail, grand juries could indict him for sedition and criminal syndicalism, legislative committees could seize his private papers ... and United States Senators would be clamoring for his deportation that he... should be sent back to live with the rest of the terrorists." - Frank I. Cobb
zoL is offline   Reply With Quote
Old 03-05-2008, 12:49 PM   #2
jackal2000
jackal2000's Avatar
lose some weight fatty.
Old 03-05-2008, 12:52 PM   #3
zoL
zoL's Avatar
Stfu newb.
Old 03-05-2008, 04:17 PM   #4
Trickyslick
Trickyslick's Avatar
Have it looked at professionally dont think bad spring/struts would do anything but give you a shitty ride and eat your tires??? Would it...sorry but that was funny jackal...sorry zol.
Old 03-05-2008, 04:41 PM   #5
Vinalero
Vinalero's Avatar
First, let go some steam.
Second, I'd start by checking by yourself where they are possibly rubbing. (maybe its just a piece of the well that was disconnected from the fender or something like this that is rubbing)
Third, depending on what you saw at second, I'd buy the required stuff needed to repair if you know what is wrong or like Tricky said, take it to a professional.
I dont think its a question where we can point out a precise problem. If it started to rubb suddenly, something has to be wrong tough.
Old 03-05-2008, 05:43 PM   #6
im guessing that the tire is rubbing where the gap inbetween your wheel and fender would be right? if thats the case yours springs are shot and your probably going to have to replace yours struts aswell.
Old 03-05-2008, 05:59 PM   #7
zoL
zoL's Avatar
I don't know if it's rubbing against the well, I just assume it is. Because I had new rotors and pads put in after the noise happened because I already had them laying around...but the noise didn't go away.
But what is weird is that I would assume that if it was rubbing against the well it would be making the noise non-stop. Which it isn't. The noise only happens when I'm 10+mph. I know that's not really fast, but when I'm going 5mph there is no noise whatsoever.
The noise sounds like...uh...you know when you were an ahoe kid, and you taped a playing card on the frame and put it through the spokes. It sounds like that... I don't know how else to explain it.
Old 03-05-2008, 06:09 PM   #8
Trickyslick
I would get under and look around. Might just be something simple thats loose. Good Luck.
Old 03-05-2008, 06:10 PM   #9
Hubs?
Remove the wheel and look around the wheel and inside the well. If it's as bad as you say, you should see marks. But I'm voting for the hubs.
Yes Jackel's comment was funny
