Old 03-15-2008, 01:10 AM   #1
Which ones positive?
Well, got pulled over tonight. The same cop I was complaining about being a rooster before decided to make it up by giving me a warning. I bought my headlight assemblies from AnderbrA about a year and a half ago, and they were in excellent condition. However somehow his wires to the bulbs were cut so he rigged his own custom setup with no solder.. I thought okay they work.. theyve worked all this time but finally the custom job came loose and the thing just came apart. so what i need to know is, on the passenger headlight assembly I have a red and a white wire. Im thinking the red is probably negative. but id like to be absolutely sure Which one is positive?
Old 03-15-2008, 03:48 AM   #2
id say red postive! u can always test it or follow the wire
Old 03-15-2008, 08:33 AM   #3
red is usually positive
Old 03-15-2008, 11:23 AM   #4
misslindseysue
MINIac
misslindseysue's Avatar
misslindseysue is an unknown quantity at this point
Send a message via AIM to misslindseysue
In general, red is hot and white is ground. But get a $15 multi-meter at Sears and you can find out.
misslindseysue is offline   Reply With Quote
Old 03-15-2008, 11:57 AM   #5
^^or you could get a 2 dollar test light, and put the aligator clip to a good ground and probe the wires...if you see the light light up then its hot if not then it is ground. Simple
Old 03-15-2008, 12:52 PM   #6
Vinalero
Vinalero's Avatar
im with lonnie, only thing im wondering is how much current is going thru the headlight. Maybe the test bulb will just explode lol
Old 03-15-2008, 01:19 PM   #7
Current is based on the bulb. Voltage is what is important.
