Old 03-24-2008, 11:17 AM   #1
amp under seat
I am thinkin of mounting my door pod amp under my passanger side seat. any suguesstions or information on things to avoid ? or should I just mount it in the trunk ? Im torn if I do it in the trunk I am not the type to just throw it in there. I would build some kinda wall or something and I don't know if I want to get in to that right now. I don't want it mounted on the back seat
Old 03-24-2008, 11:26 AM   #2
if you go under the seat, you will have to watch the little heater vent for the back seat that is under the seats... that is all i can think of that would get in the way, and possible make the amp too hot and not let it ventilate to cool properly...
Old 03-24-2008, 12:13 PM   #3
You may have issues with your grounds.
Your radio is grounded up front, amp under the seat then an amp in back for subs... Not good.
Easiest thing to do is make a simple amp rach, thats what I did.
I cut up some 3/4" MDF to fit right under that formed square bar behind the seat. Take a look in the trunk you will see it.
I recessed some "T" mounting brackets into the mdf, covered it. Secured it to the top square bad with 4 self drilling/tapping sheet metal screws. It was pretty solid.
Old 03-24-2008, 01:25 PM   #4
i would say buid a wall like i did, unless you really dont have the room, but i doubt that.
the champ didnt have room but still got it done
Old 03-24-2008, 01:37 PM   #5
Ryan do you have some pics of the back? I would like to see the brackets to hold it in there and what it looks like from the back. I've been wanting something like this for some time now.
Old 03-24-2008, 09:33 PM   #6
I will see what I can do to get some pics tomorrow night.
Thats the bracket I used. Got it at Lowes.
If you look up in the trunk theres a straight flat piece running the width of it. I cut the board so it would be snug. Used my router to flush mount the T Brackets. The top of the T then simply screwed into the flat piece on the ho.
Beware my trunks a disaster right now... lol.
Old 03-24-2008, 09:39 PM   #7
Cool I would appreciate it and if this is that easy then I would love to do this for mine. As soon as I seen the pic I could tell where you got it from and could probably tell you which Aisle cause I'm in there at least twice a week LOL!. Do you remember the measurements? If not I could get them but any info in advance is a plus. Thanks!
Old 03-27-2008, 06:42 PM   #8
Theres the pics of the area I was talking about. notice the holes.
I didnt get a pic of my amp rack thats down, darns the rain/snow/sleet/hail mix we got going on...
You will notice I had to trim away a bunch of plastic also. The board fit very snug between the towers and I had to cut some 45' degree angles to clear the radius in the corners. The 45's were tight and helped keep it all in place. It wasnt rock solid, but it wasnt moving anywhere either. I tend to err in part to doing as little modifications as possible, no holes I dont really have to, etc.
Old 03-28-2008, 07:56 AM   #9
Oh ok Thanks Ryan I see exactly what you did I knew what you were talking about just had to see what the back looked like. Then this is a pretty cool and simply thing to do I noticed on yours that you didn't carpet it any reason? I know once I do this that I'm going to carpet it. Hopefully I have enough space to get 3 amps and a crossover on it. Does this cause any change in sub performance that you noticed, and did you try to keep it air tight at all, what are your thoughts on that?
Old 03-28-2008, 10:17 AM   #10
think I might do what ryan did but put the amps on the trunk side. did you attach the bottom of the mdf ? or the sides ? or just the top
Old 03-28-2008, 11:02 AM   #11
Damn I forgot to ask that! Yeah what about the bottom Ryan I assume that its not attached there because of the snuggness of the sides. It almost looks posibble to put a hinge in it at the top to lift it up towards the rear if you needed to get something in there, just a thought of course.
Old 03-28-2008, 12:11 PM   #12
Its covered in Grey Vinyl, no carpet.
Its not attached accept for the top.
I run my wires straight down and grounded to the floor at the welded seam.
You can always buils a box with an amp rack right on it.
Old 03-28-2008, 01:13 PM   #13
Yeah the only thing about that is if someone takes your box then they take everything, and we got some fully equip theives around here that carry tools and crap. I'd rather them see the box and say ok I'll grab this and not worry about the amps, cause they wont see them.
